[mapserver-users] Production mapserver
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Mar 21 13:57:46 EDT 2011
On 3/21/2011 1:52 PM, Smith, Michael ERDC-CRREL-NH wrote:
> In the benchmark testing we did last year, see
> http://wiki.osgeo.org/wiki/Benchmarking_2010, I tested MapServer with
> minimal formats (just PostGIS) compiled it vs MapServer with Oracle,
> PostGIS, GDAL/OGR. There was no difference affect on performance by having a
> minimal build.
Mike,
While this might be true, having a minimal built does potentially
require less memory for the processes running which more available for
file cache performance that might have an impact in a production
environment, especially if you are trying to push a lot of map draws
through the system.
Another trick you can do on Linux, is to disable the swap partition if
you do not need it, and if you are just serving mapserver requests you
do not. This will improve performance by 1-2% on the system, because
Linux is what is called a swappy OS, ie it has a how propensity to swap
stuff to disk in anticipation that it might need the memory for
something else.
-Steve W
