[mapserver-users] WCS
David Hildebrand
David.Hildebrand at afsc.ca
Wed Mar 23 13:37:33 PDT 2011
I'm not sure if anyone remembers this post from a while ago or not but I
discovered a solution. I am running MapServer 5.3-dev and testing WCS
1.0.0. I discovered that the RESPONSE_CRS parameter must be the same as
the CRS parameter (or, more simply, not be used at all). If they are
different an error is generated with respect to the bounding box of the
request being outside the bounding box of the coverage. It doesn't seem
to matter whether or not the coordinate system of the request is the
same as the coordinate system of the source. The coordinate system of
the response will be the same as the coordinate system of the request.
The issue here is that the RESPONSE_CRS parameter does not seem to have
been implemented correctly and, considering that the parameter is
optional, perhaps it's not a big issue. Just something the user needs
to be aware of.
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <about:www.afsc.ca> <http://www.afsc.ca
<http://www.afsc.ca/> >
This communication is intended for the use of the recipient to which it
is addressed, and may contain confidential, personal and/or privileged
information. Please contact Agriculture Financial Services Corporation
immediately if you are not the intended recipient of this communication,
and do not copy, distribute, or take action relying on it. Any
communication received in error, or subsequent reply, should be deleted
or destroyed. Please consider the environment before printing this
email.
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of David
Hildebrand
Sent: Tuesday, February 01, 2011 4:46 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] WCS
I am trying to develop a WCS layer (1.0.0) and I can successfully issue
the GetCapabilities and DescribeCoverage requests. However, when I
issue a GetCoverage request I get a bounding box error due to bad
coordinates. The layer is also set up as a WMS layer (1.1.1) and a
GetMap request works fine. The metadata ows_srs and ows_resolution
parameters are being used in the map file and these work fine for WMS
requests. Should I be using version 1.1.0?
Any ideas?
David V. Hildebrand
(403) 782-8239
www.afsc.ca <http://www.afsc.ca>
email.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110323/bb48490e/attachment.htm>
More information about the MapServer-users
