[mapserver-users] MapServer 6.0.0-beta3 release
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Thu Mar 24 04:05:14 EDT 2011
Packages for RHEL/CentOS/Scientific Linux 5 and as src.rpm:
http://www.r3-gis.com/upload/mapserver-6.0.0beta3-1.0.el5.src.rpm
http://www.r3-gis.com/upload/mapserver-6.0.0beta3-1.0.el5.x86_64.rpm
http://www.r3-gis.com/upload/php-mapserver-6.0.0beta3-1.0.el5.x86_64.rpm
http://www.r3-gis.com/upload/php-mapserver-proj-6.0.0beta3-1.0.el5.x86_64.rpm
http://www.r3-gis.com/upload/mapserver-perl-6.0.0beta3-1.0.el5.x86_64.rpm
http://www.r3-gis.com/upload/mapserver-python-6.0.0beta3-1.0.el5.x86_64.rpm
http://www.r3-gis.com/upload/mapserver-java-6.0.0beta3-1.0.el5.x86_64.rpm
http://www.r3-gis.com/upload/mapserver-debuginfo-6.0.0beta3-1.0.el5.x86_64.rpm
These packages depend on http://wiki.osgeo.org/wiki/Enterprise_Linux_GIS and on the php53* packages, which might be found in http://dev.centos.org/centos/5/testing/x86_64/RPMS/php53/ , until CentOS 5.6 is out.
Peter
R3 GIS Srl - GmbH
--------Daniel Morissette <dmorissette at mapgears.com> wrote--------
Subject: [mapserver-users] MapServer 6.0.0-beta3 release
Date: 23.03.2011 22:45
>The MapServer Team is pleased to announce the release of MapServer
>6.0.0-beta3. This is the latest beta on our way to a final 6.0 release.
>We realize that it comes only 5 days after beta2, but it also contains
>several important fixes and we encourage you to test it and continue to
>provide feedback.
>The 6.0 release introduces important changes in key components of the
>MapServer core (rendering, query and expressions), and for this reason
>we count on you, MapServer power users, to help test the release in your
>respective environments and provide feedback (through the users list or
>Trac tickets).
>This is the third of four planned beta releases and if all goes well a
>final release should occur around the end of April. The full release
>plan which also includes the list of new features and changes in this
>release is available at:
> http://mapserver.org/trunk/development/release/release-plan-6.0.html
>The list of fixes since beta1 is attached at the end of this message.
>For a complete list see the HISTORY.TXT file at:
>http://trac.osgeo.org/mapserver/browser/tags/rel-6-0-0-beta3/mapserver/HISTORY.TXT
>We have started working on a 5.6 -> 6.0 migration guide. This document
>contains important notes on backwards incompatibilities or other changes
>required when upgrading to 6.0. It is not complete yet but we strongly
>recommend that you review the latest version online at:
> http://mapserver.org/trunk/MIGRATION_GUIDE.html
>The source for this release can be downloaded at:
> http://mapserver.org/download.html
>or
> http://download.osgeo.org/mapserver/mapserver-6.0.0-beta3.tar.gz
>The binary distributions listed in the download page should be updated
>with binaries for the new beta release in the next day or so.
>Once again we need your help to ensure a high quality product, so please
>help out by testing your applications with this new code base.
>Thanks! - The MapServer Team
>Version 6.0.0-beta3 (2011-03-23)
>- apply min/max size/width style values to polygon spacing (vaguely
>related
> to #3132)
>- assure that a created tile has a non-zero width and height (#3370)
>- use png_sig_cmp instead of png_check_sig (#3762)
>- Rendering: scale style OFFSET and GAP the same way we scale other style
> attributes. Beforehand, we scaled them proportionaly to the computed
>width.
>- KML: fix rounding problem for point feautres (#3767)
>- KML: update code to reflect output changes. Fix true type symbols.
>(#3766)
>- SLD: Text Symbolizer now uses the new expression syntax (#3757)
>- WFS: correct bbox values for GetFeature with featureid request (#3761)
>- Mapscript Seg Fault on mapObj->getMetaData (#3738)
>- Correct double free in msCleanup().
>- Initialize default formats in WCS.
>- Fix csharp Makefile.in (#3758)
>- Allow run-time subs in class->text (makes sense if you allow it in
> class->expression).
>- Fix build problem when --enable-cgi-cl-debug-args is enabled (#2853)
>_______________________________________________
>mapserver-users mailing list
>mapserver-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/mapserver-users
