[mapserver-users] MapServer 6.0.0-beta3 release
Alan Boudreault
aboudreault at mapgears.com
Thu Mar 24 09:57:14 EDT 2011
UbuntuGIS MapServer packages have been updated for the beta3 release:
https://launchpad.net/~ubuntugis/+archive/ubuntugis-testing/
Alan
On March 23, 2011 05:45:22 pm Daniel Morissette wrote:
> The MapServer Team is pleased to announce the release of MapServer
> 6.0.0-beta3. This is the latest beta on our way to a final 6.0 release.
> We realize that it comes only 5 days after beta2, but it also contains
> several important fixes and we encourage you to test it and continue to
> provide feedback.
> The 6.0 release introduces important changes in key components of the
> MapServer core (rendering, query and expressions), and for this reason
> we count on you, MapServer power users, to help test the release in your
> respective environments and provide feedback (through the users list or
> Trac tickets).
> This is the third of four planned beta releases and if all goes well a
> final release should occur around the end of April. The full release
> plan which also includes the list of new features and changes in this
> release is available at:
> http://mapserver.org/trunk/development/release/release-plan-6.0.html
> The list of fixes since beta1 is attached at the end of this message.
> For a complete list see the HISTORY.TXT file at:
> http://trac.osgeo.org/mapserver/browser/tags/rel-6-0-0-beta3/mapserver/HIST
> ORY.TXT
> We have started working on a 5.6 -> 6.0 migration guide. This document
> contains important notes on backwards incompatibilities or other changes
> required when upgrading to 6.0. It is not complete yet but we strongly
> recommend that you review the latest version online at:
> http://mapserver.org/trunk/MIGRATION_GUIDE.html
> The source for this release can be downloaded at:
> http://mapserver.org/download.html
> or
> http://download.osgeo.org/mapserver/mapserver-6.0.0-beta3.tar.gz
> The binary distributions listed in the download page should be updated
> with binaries for the new beta release in the next day or so.
> Once again we need your help to ensure a high quality product, so please
> help out by testing your applications with this new code base.
> Thanks! - The MapServer Team
> Version 6.0.0-beta3 (2011-03-23)
> - apply min/max size/width style values to polygon spacing (vaguely related
> to #3132)
> - assure that a created tile has a non-zero width and height (#3370)
> - use png_sig_cmp instead of png_check_sig (#3762)
> - Rendering: scale style OFFSET and GAP the same way we scale other style
> attributes. Beforehand, we scaled them proportionaly to the computed
> width.
> - KML: fix rounding problem for point feautres (#3767)
> - KML: update code to reflect output changes. Fix true type symbols.
> (#3766)
> - SLD: Text Symbolizer now uses the new expression syntax (#3757)
> - WFS: correct bbox values for GetFeature with featureid request (#3761)
> - Mapscript Seg Fault on mapObj->getMetaData (#3738)
> - Correct double free in msCleanup().
> - Initialize default formats in WCS.
> - Fix csharp Makefile.in (#3758)
> - Allow run-time subs in class->text (makes sense if you allow it in
> class->expression).
> - Fix build problem when --enable-cgi-cl-debug-args is enabled (#2853)
> mapserver-users at lists.osgeo.org
Alan Boudreault
Mapgears
http://www.mapgears.com
