[mapserver-users] Too many open files...
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Mar 28 17:29:22 EDT 2011
On 3/28/2011 5:05 PM, Lee Meilleur wrote:
> Hello,
> Has anyone run into the error: “Too many open files: couldn’t set child
> process attributes: /var/www/cgi-bin/mapserv”? This error shows up in an
> Apache error_log. A broken image now shows up for MapServer layers since
> this started. I’ve tried changing the ulimits or the MaxRequestsPerChild
> for Apache with no luck. Any other ideas?
You probably need to give us more information like:
Which OS?
Which Apache version?
Which Apache MPM module are you using?
/var/www/cgi-bin/mapserv -v output?
Does this happen when you run shp2img?
What are you serving via mapserver? vectors, imagery, database, etc?
-Steve W
