[mapserver-users] USING UNIQUE with multiple fields
geographika
geographika at gmail.com
Tue Mar 29 16:38:30 EDT 2011
Thanks Tamas and Jukka for you replies. I'll be able to work around it
with a view as suggested.
It would be good to clarify the USING UNIQUE clause somewhere in the docs.
web:http://geographika.co.uk
twitter: @geographika
On 29/03/2011 12:39, Tamas Szekeres wrote:
> Hi,
> That is not possible, the feature ID must be an integer field with the
> current implementation.
> Best regards,
> Tamas
> 2011/3/29 geographika <geographika at gmail.com
> <mailto:geographika at gmail.com>>
> Hi
> I have a feature table which I'm serving out as a WFS. It has a
> two column unique index - is there support for this in a LAYER
> definition in a mapfile?
> E.g. DATA "GEOM from mytable USING SRID=29902 USING UNIQUE
> Field1,Field2
> I presume not as I've tried a few combinations with no success,
> but just wondered if this is possible. I'm using a SQL Server 2008
> connection.
> Thanks for any help,
> Seth
> mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110329/9f1ae55e/attachment-0001.html
