[mapserver-users] WFS Intersect with gml:box
Yewondwossen Assefa
yassefa at dmsolutions.ca
Wed Mar 30 16:48:08 EDT 2011
On 30/03/2011 4:16 PM, Rahkonen Jukka wrote:
> Hi,
> "Intersect" means the same as "not disjoint", that the two geometries have at least one point in common. Thus WFS Intersects should select the point that is inside the "box" in the query. I made a quick test with OpenJUMP which is using JTS and it really does select such a point with a apatial query Intersects.
Geos lib used by MapServer should act the same as JTS I beleive.
Joaquín, you can maybe attach your simple map/data/url to the bug and I
will check it using MapServer trunk.
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
