[mapserver-users] MapServer 6.0.0-beta4 release
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Thu Mar 31 04:58:10 EDT 2011
Packages for RHEL/CentOS/Scientific Linux 5 and as src.rpm:
http://www.r3-gis.com/upload/mapserver-6.0.0beta4-1.0.el5.src.rpm
http://www.r3-gis.com/upload/mapserver-6.0.0beta4-1.0.el5.x86_64.rpm
http://www.r3-gis.com/upload/php-mapserver-6.0.0beta4-1.0.el5.x86_64.rpm
http://www.r3-gis.com/upload/php-mapserver-proj-6.0.0beta4-1.0.el5.x86_64.rpm
http://www.r3-gis.com/upload/mapserver-perl-6.0.0beta4-1.0.el5.x86_64.rpm
http://www.r3-gis.com/upload/mapserver-python-6.0.0beta4-1.0.el5.x86_64.rpm
http://www.r3-gis.com/upload/mapserver-java-6.0.0beta4-1.0.el5.x86_64.rpm
http://www.r3-gis.com/upload/mapserver-debuginfo-6.0.0beta4-1.0.el5.x86_64.rpm
These packages depend on http://wiki.osgeo.org/wiki/Enterprise_Linux_GIS and on the php53* packages, which might be found in http://dev.centos.org/centos/5/testing/x86_64/RPMS/php53/ , until CentOS 5.6 is
out.
In addition to the beta3 packages, KML support is enabled. beta3 packages were removed.
Peter
R3 GIS Srl - GmbH
--------Daniel Morissette <dmorissette at mapgears.com> wrote--------
Subject: [mapserver-users] MapServer 6.0.0-beta4 release
Date: 31.03.2011 03:36
>The MapServer Team is pleased to announce the release of MapServer
>6.0.0-beta4. This is the latest beta on our way to a final 6.0 release.
>Once again this beta contains several important fixes and we encourage
>you to test it and continue to provide feedback.
>The 6.0 release introduces important changes in key components of the
>MapServer core (rendering, query and expressions), and for this reason
>we count on you, MapServer power users, to help test the release in your
>respective environments and provide feedback (through the users list or
>Trac tickets).
>If all goes well, the plan is to have a final 6.0 release around the end
>of April. The full release plan which also includes the list of new
>features and changes in this release is available at:
> http://mapserver.org/trunk/development/release/release-plan-6.0.html
>The list of fixes since beta1 is attached at the end of this message.
>For a complete list see the HISTORY.TXT file at:
>http://trac.osgeo.org/mapserver/browser/tags/rel-6-0-0-beta4/mapserver/HISTORY.TXT
>We have started working on a 5.6 -> 6.0 migration guide. This document
>contains important notes on backwards incompatibilities or other changes
>required when upgrading to 6.0. It is not complete yet but we strongly
>recommend that you review the latest version online at:
> http://mapserver.org/trunk/MIGRATION_GUIDE.html
>The source for this release can be downloaded at:
> http://mapserver.org/download.html
>or
> http://download.osgeo.org/mapserver/mapserver-6.0.0-beta4.tar.gz
>The binary distributions listed in the download page should be updated
>with binaries for the new beta release in the next day or so.
>Once again we need your help to ensure a high quality product, so please
>help out by testing your applications with this new code base.
>Thanks! - The MapServer Team
>Version 6.0.0-beta4 (2011-03-30)
>- Fix shp2img's -i flag to honour map level transparent, image quality
>and
> interlace settings.
>- Make sure command-line programs use an exit status other than 0
> when an error is encountered. (#3753)
>- Applied patch to filter unwanted fribidi characters (#3763)
>- Fixed lexer to set the proper state on URL variable substitutions
>- Fixed Memory leak in PostGIS driver (#3768)
>- Fixed PHP/MapScript symbol property setter method
>- fix memory leak in bar charts
>- fix some valgrind errors on agg rotated pixmap symbols
>- WCS 2.0: Adjusted definition of NilValues.
>- Fixed handling of PROJ_LIB value relative to mapfile path (#3094)
>- Fixed compilation error with opengl support (#3769)
>- add support for gml:Box for spatial filters (#3789)
>- fix query map generation error introduced in beta2 when output format
> initialized was made as needed.
>- fix incorrect PATTERN behavior on agg lines (#3787)
>- report SOS DescribeObservationType in Capabilities (#3777)
>- Updated lexer to detect time attribute bindings (e.g. `[item]`) in
>logical
> expressions
>- Fixed layer context expressions (REQUIRES/LABELREQUIRES) (#3737)
>- KML: Output ExtendedData (#3728)
>- Fixed OWS usage of multiple layers with same name (#3778)
>- WCS implementation should not lookup wms_* metadata (#3779)
>- WCS 2.0: Adjusted definition of rangeType.
>- Fixed OWS GetCapabilities to report only requests/operations that are
> enabled.
>- WCS 2.0: Report only bands in the range subset.
>- OWS requests should be completely blocked by default (#3755)
>- SLD: check for limit on dash arrays (#3772)
>- WMS: Apply sld after bbox and srs have been parsed (#3765)
>_______________________________________________
>mapserver-users mailing list
>mapserver-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/mapserver-users
