[mapserver-users] Re: Reaspect?
SixDegrees
paulcarlisle at comcast.net
Wed Nov 2 09:35:26 PDT 2011
That's pretty much what we've decided to do, although the resulting image is
no longer square. We could, of course, do that, too. But this seems like
work that really belongs on the server, not on the client side, where all I
want to do is request an image and have it passed back to me, trimmed the
way I asked.
Rahkonen Jukka wrote:
> Hi,
> That's how the WMS standard is written. Request must contain BBOX, WIDTH
> and HEIGHT and server must respect them all.
> Reaspect parameter does do something useful against some ArcIMS servers
> which are configured in a certain way.
> Could you describe mose closely when would you need so muct new code?
> Isn't taking the BBOX and calculating MaxX-MinX and MaxY-MinY, and then
> taking either WIDTH or HEIGHT as given and calculating the missing one
> good enough for your use case?
> -Jukka Rahkonen-
> SixDegrees wrote:
>> That makes me sad, because I really need an ability similar to what I've
> described. I can probably pull it off on my own, but that will require a
> fair amount of new code to accommodate pixels that are widely different
> in
> width and height in many of our images.
>> A capability similar to HTML's IMG tag, where the WIDTH and HEIGHT are
> strictly obeyed when both are present, but the original image's aspect
> ratio
> is maintained when one or the other is left off, would be ideal.
> I really hope this is not correct, and that the reaspect parameter will do
> something useful. I can experiment tomorrow when I'm back at the server.
>> Hi,
>> Reaspect does not seem to do anything with Mapserver acting as WMS
>> server.
>> The example here http://mapserver.org/trunk/faq.html is for Mapserver
>> acting as a WMS client and reading data from some ArcIMS servers.
>> -Jukka Rahkonen-
>> SixDegrees wrote:
>>> Can someone provide an example of what the 'reaspect' parameter of a wms
>> request will do when Mapserver receives it in a GetMap request? As I
>> understand it (poorly) the WIDTH and HEIGHT will remain the same, but if
>> 'reaspect=true' the BBOX may be adjusted so the aspect ratio of the
>> projected image is preserved and WIDTH and HEIGHT just specify a "window"
>> onto this "correctly" proportioned rendering, while if 'reaspect=false'
>> the
>> BBOX is retained along with WIDTH and HEIGHT and the image is
>> stretched/squished to fit. Is this correct, or am I completely
>> misunderstanding this?
>>> Also, if the above is true and 'reaspect=true' is set, how is the
>>> "window"
>> defined by WIDTH and HEIGHT placed onto the image? Is it centered with
>> respect to the BBOX? Placed against one of the corners? Or something else
>> altogether?
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Reaspect-tp6953208p6953208.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> mapserver-users at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> http://osgeo-org.1803224.n2.nabble.com/Reaspect-tp6953208p6953294.html
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Reaspect-tp6953208p6955963.html
More information about the MapServer-users
