[mapserver-users] Problem with ecw raster layer
luis peinado
luis.peinado at geodata.es
Fri Nov 4 05:04:01 EDT 2011
Hi, thanks a lot for your response, that was the problem (no ecw support
for gdal).
I solved it using Jeff McKenna method:
http://osgeo-org.1803224.n2.nabble.com/ECW-Problems-td1971907.html
Best wishes.
2011/11/4 Richard Greenwood <richard.greenwood at gmail.com>
> On Thu, Nov 3, 2011 at 5:31 AM, luis peinado <luis.peinado at geodata.es>
> wrote:
> > Hi list,
> > I've been working for days trying to render a .ecw file using a raster
> > layer.
> > The same map file and ecw file work fine with other 2 servers (using
> Linux
> > and different mapserver versions:4.6 and 5.6) as shown here:
> http://www.anthos.es/wms46/rjb/anthos/raster?REQUEST=GetMap&VERSION=1.1.1&LAYERS=nasa_240&STYLES=&SRS=EPSG:4326&FORMAT=image/jpeg&BBOX=-18.88692529000388,31.01113086496096,-7.695976464653308,40.51093762077761&WIDTH=761&HEIGHT=646&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_xml&SERVICE=WMS
> > On my new server (Scientific Linux and mapserver 5.6) I get a file with
> no
> > images inside, and mapserver log does not explain any error, everything
> > seems to be alright for it.
> > The image shown is this:
> http://161.111.171.50/wms46/rjb/anthos/raster?REQUEST=GetMap&VERSION=1.1.1&LAYERS=nasa_240&STYLES=&SRS=EPSG:4326&FORMAT=image/jpeg&BBOX=-18.88692529000388,31.01113086496096,-7.695976464653308,40.51093762077761&WIDTH=761&HEIGHT=646&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_xml&SERVICE=WMS
> > Mapserver's log:
> > [Thu Nov 3 12:28:40 2011].651297 CGI Request 1 on process 32018
> > [Thu Nov 3 12:28:40 2011].655439 msDrawMap(): Layer 3 (nasa_240), 0.000s
> > [Thu Nov 3 12:28:40 2011].655485 msDrawMap(): Drawing Label Cache,
> 0.000s
> > [Thu Nov 3 12:28:40 2011].655491 msDrawMap() total time: 0.003s
> > [Thu Nov 3 12:28:40 2011].698421 msSaveImage() total time: 0.043s
> > [Thu Nov 3 12:28:40 2011].699261 mapserv request processing time
> (msLoadMap
> > not incl.): 0.048s
> > [Thu Nov 3 12:28:40 2011].699271 msFreeMap(): freeing map at 0x8927220.
> > [Thu Nov 3 12:28:40 2011].946127 CGI Request 1 on process 32019
> > [Thu Nov 3 12:28:40 2011].950267 msDrawMap(): Layer 3 (nasa_240), 0.000s
> > [Thu Nov 3 12:28:40 2011].950312 msDrawMap(): Drawing Label Cache,
> 0.000s
> > [Thu Nov 3 12:28:40 2011].950318 msDrawMap() total time: 0.003s
> > [Thu Nov 3 12:28:40 2011].993148 msSaveImage() total time: 0.043s
> > [Thu Nov 3 12:28:40 2011].993921 mapserv request processing time
> (msLoadMap
> > not incl.): 0.048s
> > [Thu Nov 3 12:28:40 2011].993930 msFreeMap(): freeing map at 0x1ec32220.
> > And mapserver's version information:
> > /var/www/cgi-bin/mapserv -v
> > MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> > OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
> > SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> > SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
> > SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> > So, can someone help telling me where to look for the error?
> > Thanks a lot for any help or suggestion.
> > Lluís
> ECW is a proprietary format and thus may not have been installed with
> your Linux distro. I'm not familiar with Scientific Linux so I don't
> know. If you do have ECW support it would be handled by GDAL, which
> you have as evidenced by INPUT=GDAL, so you need to determine if GDAL
> has ECW support, which is pretty easy. In the shell:
> gdalinfo --formats
> or better yet
> gdalinfo --formats | grep -i ecw
> will list the formats tha GDAL can handle in your setup.
> If ECW isn't in the list then you need to install or build supporting
> libraries, but I have no idea how you do that in Scientific Linux.
> HTH,
> Rich
> Richard Greenwood
> www.greenwoodmap.com
*Lluís Peinado*
***Geodata Sistemas,SL.*
T. 933 035 367 (ext. 21)
F. 933 080 071
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111104/db834f33/attachment.html
