[mapserver-users] MS4W Crash: Faulting app: mapserv.exe,
module: libmap.dll
vaibhavgarg
vaibhavkumargarg at gmail.com
Mon Nov 7 08:33:42 EST 2011
I am trying to get MS4W to dish out tile for use in google maps as overlay.
I was successful in making it work with a sample data set but when pointing
it to the full set, it crashes:
Windows 7 Event Log:
/Faulting application name: mapserv.exe, version: 0.0.0.0, time stamp:
0x4e1c9886
Faulting module name: libmap.dll, version: 0.0.0.0, time stamp: 0x4e1c9885
Exception code: 0xc0000005
Fault offset: 0x00005db6
Faulting process id: 0xc2c
Faulting application start time: 0x01cc9d49ca7b11ac
Faulting application path: C:\ms4w\Apache\cgi-bin\mapserv.exe
Faulting module path: C:\ms4w\Apache\cgi-bin\libmap.dll
Report Id: 0c7e2d19-093d-11e1-8aea-0025228983f5/
Apache Log:
/[Mon Nov 07 13:02:14 2011] [error] [client 117.201.84.121] Premature end of
script headers: mapserv.exe/
The machine is Windows 7 Home Premium SP1 x64, Core i5 2500K 3.30Ghz, 8GB
Ram, Lots of disk space
The OS is fresh install, MS4W is fresh too.
The Tile URL looks like this:
/http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/apps/hampshire/Hampshire.map&layers=HampshireAreas%20HampshirePoints%20HampshireLines&mode=tile&tilemode=gmap&tile=129599+87740+18/
Dataset is .SHP format and about 30GB in size.
*Map File:*The only change in the small data set and the full data set's map
files is the path to the data files. Rest of it is exactly the same.
/MAP
NAME WMS_Server
SIZE 256 256
UNITS METERS
EXTENT 399353.025466 117022.852602 399809.101028 117313.950158
FONTSET 'fonts.txt'
SYMBOLSET 'symbols.txt'
STATUS ON
PROJECTION
"proj=merc"
"a=6378137"
"b=6378137"
"lat_ts=0.0"
"lon_0=0.0"
"x_0=0.0"
"y_0=0"
"k=1.0"
"units=m"
"nadgrids=@null"
"no_defs"
END
IMAGECOLOR 255 255 255
IMAGEQUALITY 95
IMAGETYPE png
OUTPUTFORMAT
NAME png
DRIVER 'GD/PNG'
MIMETYPE 'image/png'
IMAGEMODE RGB
EXTENSION 'png'
END
LEGEND
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
WEB
IMAGEPATH '/tmp/ms_tmp/'
IMAGEURL '/tmp/'
METADATA
'wms_title' 'Hampshire'
'wms_onlineresource'
'http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/apps/gmap/htdocs/hampshire.map'
'wms_srs' 'EPSG:4326'
'wms_enable_request' '*'
END
TEMPLATE 'fooOnlyForWMSGetFeatureInfo'
END
LAYER
NAME 'HampshireAreas'
TYPE POLYGON
DEBUG ON
TEMPLATE fooOnlyForWMSGetFeatureInfo
DATA 'C:/ms4w/apps/Hampshire/HampshireAreas.shp'
METADATA
'wms_title' 'HampshireAreas'
END
PROJECTION
"proj=tmerc"
"lat_0=49"
"lon_0=-2"
"k=0.9996012717"
"x_0=400000"
"y_0=-100000"
"ellps=airy"
"datum=OSGB36"
"units=m"
"no_defs"
END
STATUS DEFAULT
CLASSITEM 'osgb:theme'
CLASS
NAME "default"
EXPRESSION ""
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 179 225 155
END
END
/[more style classes and two layers removed for clarity, ful MAP file
attached
http://osgeo-org.1803224.n2.nabble.com/file/n6970353/Hampshire.map.txt
Hampshire.map.txt ]/
END
END
*Please help! *
Regards,
Vaibhav Garg
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MS4W-Crash-Faulting-app-mapserv-exe-module-libmap-dll-tp6970353p6970353.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
