[mapserver-users] Re: WCS Geotiff output issue
Guillaume Loiselle
loiselle.guillaume at gmail.com
Mon Nov 7 15:32:53 EST 2011
I'm afraid it isn't. I didn't notice the request version I sent was a
"mixed" one but I tried Coverage on 1.0.0 and Identifier on 1.1.0 as well
and the result was basically the same.
Here is the 1.1.0 version of the error :
<?xml version="1.0" encoding="ISO-8859-1"?>
<ows:ExceptionReport xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ows="http://www.opengis.net/ows/1.1" version="1.1.0" xml:lang="en-US"
xsi:schemaLocation="http://www.opengis.net/ows/1.1
http://schemas.opengis.net/ows/1.1.0/owsExceptionReport.xsd">
<ows:Exception exceptionCode="bbox" locator="NoApplicableCode">
<ows:ExceptionText>
msWCSGetCoverage(): WCS server error. Requested BBOX
(-178.804111261525,2802.84894277903,179.578125552223,2907.18853507175) is
outside requested coverage BBOX (-70,45,-55,52)</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
I of course spent a lot of time on the WCS server documentation page. I saw
no reference to such a problem, though. My request,
http://localhost/cgi-bin/mapserv.exe?
map=D:/Guillaume/ProjetCourantsGlaces/WCSproblem/2011102811.map&
SERVICE=WCS&
VERSION=1.0.0&
REQUEST=GetCoverage&
COVERAGE=thelayer&
CRS=EPSG:4326&
BBOX=-67.5,48.922499263758255,-64.6875,50.736455137010665&
WIDTH=256&
HEIGHT=256&
FORMAT=GTiff
is formatted the same way the example is :
http://my.host.com/cgi-bin/mapserv?
map=mywcs.map&
SERVICE=wcs&
VERSION=1.0.0&
coverage=bathymetry&
CRS=EPSG:42304&
BBOX=-2200000,-712631,3072800,3840000&
WIDTH=3199&
HEIGHT=2833&
FORMAT=GTiff
My mapfile contains every required attribute.
Thank you.
Guillaume Loiselle
2011/11/7 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> Hi,
> See examples in http://www.mapserver.org/ogc/wcs_server.html and try to
> avoid mixing versions 1.0.0 and 1.1.0. Let's hope using "coverage" instead
> of "identifier" will be enough.
> -Jukka Rahkonen-
> ________________________________
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org [
> mapserver-users-bounces at lists.osgeo.org] käyttäjän Guillaume Loiselle [
> loiselle.guillaume at gmail.com] puolesta
> Lähetetty: 7. marraskuuta 2011 21:21
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] Re: WCS Geotiff output issue
> Hi,
> For some reason, the text part of the email didn't make it. It can be read
> below.
> Attachments can still be found in the first message :
> http://lists.osgeo.org/pipermail/mapserver-users/2011-November/070670.html
> Thanks.
> Guillaume Loiselle
> 2011/11/4 Guillaume Loiselle <loiselle.guillaume at gmail.com<mailto:
> loiselle.guillaume at gmail.com>>
> Hi,
> I installed MapServer 6.0.1 on Windows XP from MS4W. I cannot give you
> access to my MapServer instance but I can show you what "-v" gives me :
> MapServer version 6.0.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
> SUPPORTS=PR
> OJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=FRIBIDI
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
> SUPPO
> RTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> I am able to generate a GeoTiff file through the use of a WMS service (see
> attachment : wmsoutput.tif). The request is :
> http://localhost/cgi-bin/mapserv.exe?SERVICE=WMS&map=D:/Guillaume/ProjetCourantsGlaces/WCSproblem/2011102811.map&LAYERS=thelayer&VERSION=1.1.1&REQUEST=GetMap&bbox=-67.5,48.922499263758255,-64.6875,50.736455137010665&SRS=EPSG:4326&WIDTH=256&HEIGHT=256&FORMAT=GTiff
> However, I cannot do so with a WCS service. I first tried with :
> http://localhost/cgi-bin/mapserv.exe?SERVICE=WCS&map=D:/Guillaume/ProjetCourantsGlaces/WCSproblem/2011102811.map&IDENTIFIER=thelayer&VERSION=1.0.0&REQUEST=GetCoverage&BBOX=-67.5,48.922499263758255,-64.6875,50.736455137010665&CRS=EPSG:4326&WIDTH=256&HEIGHT=256&FORMAT=GTiff
> , to which I can add :
> &RESPONSE_CRS=EPSG:4326
> for the same result (since 4326 is my native projection). Said result is
> not a tiff file, but an error :
> <?xml version='1.0' encoding="ISO-8859-1" ?>
> <ServiceExceptionReport version="1.2.0"
> xmlns="http://www.opengis.net/ogc" xmlns:xsi="
> http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
> http://schemas.opengis.net/wcs/1.0.0/OGC-exception.xsd">
> <ServiceException code="NoApplicableCode"
> locator="bbox">msWCSGetCoverage(): WCS server error. Requested BBOX
> (-178.835708198757,2803.05273104522,179.552848002437,2906.98474680556) is
> </ServiceException>
> </ServiceExceptionReport>
> This error doesn't make sense to me. Which projection is it using to get
> these silly values? Anyway, the BBOX in the request is definitely included
> in the extent... Now what if I change the Response_CRS? I would expect it
> to give me the same error, since it doesn't affect the requested BBOX. Yet,
> this time no error is produced and I obtain a tiff file (see attachment :
> wcsoutput.tif). The data is all wrong (0 everywhere), though. And if I open
> both WMS and WCS obtained tiffs in QuantumGIS, they appear nowhere near
> each other (for the same bbox... yes).
> I attached the results of GetCapabilities and DescribeCoverage requests as
> well as the MapServer logs (modified to map logs with requests). The data
> source is an HDF5 file (see attachment : data.h5). I suspect an issue on
> MapServer's side but I would be happy if you could tell me it's all my
> fault (and how to fix it).
> Oh, a last thing : it may or may not be related. I had issues with the
> KML/KMZ WMS outputformats. Results for epsg:4326 and epsg:900913 were
> completely different (and wrong, of course). I might open a new discussion
> on this subject at some point.
> Thank you all for your help.
> Guillaume Loiselle
> P.S. : If you want to test, know that epsg:900913 is the same as epsg:3857
> (which is more likely to be in your epsg reference file).
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111107/373e8fe1/attachment.html
