[mapserver-users] WFS with several SRS?
sulu
andreas.siegel at vorarlberg.at
Tue Nov 8 05:37:48 EST 2011
I would like to offer a WFS-Service which supports several different
projections.
("WFS_SRS" "EPSG:31254 EPSG:3785 EPSG:4326 EPSG:31284 EPSG:32632
EPSG:25832 EPSG:21781")
My mapserver is of version 5.6.6 on a Centos-Box
MapServer version 5.6.6 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=FASTCGI INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
As expected the default SRS is 31254.
A GetFeature-Call with this EPSG works just fine:
Example:
http://vogis.cnv.at/cgi-bin/mapserv?map=wfs.map&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=nutzungs-grenzen&SRSNAME=epsg:31254
But if i try a other SRS from the WFS_SRS (e.g. 4326) above i receive:
msWFSGetFeature(): WFS server error. Invalid GetFeature Request: SRSNAME
value should be valid for all the TYPENAMES. Please check the capabilities
and reformulate your request.
As you can see in the Mapfile below, i avoided specifying any projection in
the layer section so i have to wonder what i am doing wrong?
Thanks
Andy
MAPFILE
MAP
EXTENT -70000 180000 5000 280000 #for EPSG:31254
FONTSET ./fontset
IMAGETYPE png
MAXSIZE 8000
RESOLUTION 96
SYMBOLSET ./etc/symbol/symbols.sym
# Debugging
CONFIG "MS_ERRORFILE" "/tmp/mapserver_wfs_error.txt"
DEBUG 5
WEB
METADATA
"WFS_TITLE" "DKM Vorarlberg"
EPSG:32632 EPSG:25832 EPSG:21781"
"WFS_ABSTRACT" "Geodaten des Bundeslandes Vorarlberg als OGC-WFS"
"WMS_SRS" "EPSG:4326 EPSG:31254 EPSG:31284 EPSG:32632
"WMS_TITLE" "DKM Vorarlberg"
"WMS_ABSTRACT" "Geodaten des Bundeslandes Vorarlberg als OGC-WMS"
#"WMS_ONLINERESOURCE"
"http://vogis.cnv.at/mapserver/mapserv?map=wfs.map&version=1.1.0"
"WMS_FORMATLIST" "image/gif,image/png,image/jpeg,image/tif"
"WMS_FEATURE_INFO_MIME_TYPE" "text/html"
END
END
OUTPUTFORMAT
NAME jpg
DRIVER "GDAL/JPEG"
MIMETYPE "image/jpeg"
IMAGEMODE RGB
EXTENSION "jpg"
END
OUTPUTFORMAT
NAME jpg
DRIVER "GDAL/JPEG"
MIMETYPE "image/jpg"
IMAGEMODE RGB
EXTENSION "jpg"
END
OUTPUTFORMAT
NAME gif
DRIVER "GD/GIF"
MIMETYPE "image/gif"
IMAGEMODE PC256
EXTENSION "gif"
END
OUTPUTFORMAT
NAME png
# Driver AGG/PNG weil der GDAL-Driver Probleme bei der Transparenz hat
DRIVER "AGG/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
TRANSPARENT ON
FORMATOPTION "INTERLACE=OFF"
END
OUTPUTFORMAT
NAME wbmp
DRIVER "GD/WBMP"
MIMETYPE "image/wbmp"
IMAGEMODE PC256
EXTENSION "wbmp"
END
OUTPUTFORMAT
NAME GTiff
DRIVER "GDAL/GTiff"
MIMETYPE "image/tiff"
IMAGEMODE RGB
EXTENSION "tif"
END
# Start of LAYER DEFINITIONS ---------------------------------------------
# Layer: Nutzungs-Grenzen
LAYER
NAME "nutzungs-grenzen"
#GROUP "nutzungs-grenzen"
METADATA
'OWS_TITLE' 'Nutzungs-Grenzen'
"WFS_TITLE" "Nutzungs-Grenzen"
"GML_INCLUDE_ITEMS" "all"
"GML_FEATUREID" "ID"
END
MAXFEATURES 1000
EXTENT -70000 180000 -1000 280000 #for EPSG:31254
DATA "/data/Geodaten/Grenzen/DKM/Vorarlberg/Nutzung/NFL"
OPACITY 100
TYPE polygon
MINSCALEDENOM 100
MAXSCALEDENOM 5001
STATUS ON
DUMP TRUE
CLASS
NAME "Nutzungs-Grenzen"
STYLE
WIDTH 0.25
ANTIALIAS false
OUTLINECOLOR 0 130 0
BACKGROUNDCOLOR 0 130 0
END #end style
END
PROCESSING "CLOSE_CONNECTION=DEFER"
END #end layer
END #end map
View this message in context: http://osgeo-org.1803224.n2.nabble.com/WFS-with-several-SRS-tp6973831p6973831.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
