[mapserver-users] WFS with several SRS?
sulu andreas.siegel at vorarlberg.at
Tue Nov 8 02:37:48 PST 2011
I would like to offer a WFS-Service which supports several different
projections.
("WFS_SRS"            "EPSG:31254 EPSG:3785 EPSG:4326 EPSG:31284 EPSG:32632
EPSG:25832 EPSG:21781")
My mapserver is of version 5.6.6 on a Centos-Box
MapServer version 5.6.6 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=FASTCGI INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
As expected the default SRS is 31254.
A GetFeature-Call with this EPSG works just fine:
Example:
http://vogis.cnv.at/cgi-bin/mapserv?map=wfs.map&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=nutzungs-grenzen&SRSNAME=epsg:31254
But if i try a other SRS from the WFS_SRS (e.g. 4326) above i receive:
msWFSGetFeature(): WFS server error. Invalid GetFeature Request: SRSNAME
value should be valid for all the TYPENAMES. Please check the capabilities
and reformulate your request.
As you can see in the Mapfile below, i avoided specifying any projection in
the layer section so i have to wonder what i am doing wrong?
Thanks
Andy
MAPFILE
MAP
	EXTENT     -70000 180000 5000 280000		#for EPSG:31254
	FONTSET    ./fontset
	IMAGETYPE  png
	MAXSIZE    8000
	RESOLUTION 96
	SYMBOLSET  ./etc/symbol/symbols.sym
	# Debugging
	CONFIG "MS_ERRORFILE" "/tmp/mapserver_wfs_error.txt"
	DEBUG 5
	WEB
		METADATA
			"WFS_TITLE"          "DKM Vorarlberg"
EPSG:32632 EPSG:25832 EPSG:21781"
			"WFS_ABSTRACT"       "Geodaten des Bundeslandes Vorarlberg als OGC-WFS"
			"WMS_SRS"            "EPSG:4326 EPSG:31254 EPSG:31284 EPSG:32632
			"WMS_TITLE"          "DKM Vorarlberg"
			"WMS_ABSTRACT"        "Geodaten des Bundeslandes Vorarlberg als OGC-WMS"
			#"WMS_ONLINERESOURCE"
"http://vogis.cnv.at/mapserver/mapserv?map=wfs.map&version=1.1.0"
			"WMS_FORMATLIST"      "image/gif,image/png,image/jpeg,image/tif"
			"WMS_FEATURE_INFO_MIME_TYPE" "text/html"
		END
	END
	OUTPUTFORMAT
		NAME jpg
		DRIVER "GDAL/JPEG"
		MIMETYPE "image/jpeg"
		IMAGEMODE RGB
		EXTENSION "jpg"
		END
	OUTPUTFORMAT
		NAME jpg
		DRIVER "GDAL/JPEG"
		MIMETYPE "image/jpg"
		IMAGEMODE RGB
		EXTENSION "jpg"
		END
	OUTPUTFORMAT
		NAME gif
		DRIVER "GD/GIF"
		MIMETYPE "image/gif"
		IMAGEMODE PC256
		EXTENSION "gif"
		END
	OUTPUTFORMAT
		NAME png
		# Driver AGG/PNG weil der GDAL-Driver Probleme bei der Transparenz hat
		DRIVER "AGG/PNG"
		MIMETYPE "image/png"
		IMAGEMODE RGBA
		EXTENSION "png"
		TRANSPARENT ON
		FORMATOPTION "INTERLACE=OFF"
	END
	OUTPUTFORMAT
		NAME wbmp
		DRIVER "GD/WBMP"
		MIMETYPE "image/wbmp"
		IMAGEMODE PC256
		EXTENSION "wbmp"
	END
	OUTPUTFORMAT
		NAME GTiff
		DRIVER "GDAL/GTiff"
		MIMETYPE "image/tiff"
		IMAGEMODE RGB
		EXTENSION "tif"
	END
	# Start of LAYER DEFINITIONS ---------------------------------------------
	# Layer: Nutzungs-Grenzen
	LAYER
		NAME "nutzungs-grenzen"
		#GROUP "nutzungs-grenzen"
		METADATA
			'OWS_TITLE' 'Nutzungs-Grenzen'
			"WFS_TITLE" "Nutzungs-Grenzen"
			"GML_INCLUDE_ITEMS"  "all"
			"GML_FEATUREID"      "ID"
		END
		MAXFEATURES 1000
		EXTENT  -70000 180000 -1000 280000	#for EPSG:31254
		DATA "/data/Geodaten/Grenzen/DKM/Vorarlberg/Nutzung/NFL"
		OPACITY  100
		TYPE polygon
		MINSCALEDENOM 100
		MAXSCALEDENOM 5001
		STATUS ON
		DUMP TRUE
		CLASS
			NAME "Nutzungs-Grenzen"
			STYLE
				WIDTH 0.25
				ANTIALIAS false
				OUTLINECOLOR 0 130 0
				BACKGROUNDCOLOR 0 130 0
			END #end style
		END
		PROCESSING "CLOSE_CONNECTION=DEFER"
	END #end layer
END #end map
View this message in context: http://osgeo-org.1803224.n2.nabble.com/WFS-with-several-SRS-tp6973831p6973831.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
More information about the MapServer-users mailing list
