[mapserver-users] subsetted output, but I don't want that
Fawcett, David (MPCA)
David.Fawcett at state.mn.us
Wed Nov 9 15:06:34 EST 2011
In MapServer, if you set a MAP level projection and extent and don't specify a projection for a layer, MapServer assumes that the layer has the same projection as the MAP.
David.
-----Original Message-----
Sent: Wednesday, November 09, 2011 1:47 PM
To: Fawcett, David (MPCA)
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] subsetted output, but I don't want that
No, it's just a plain PNG. I was operating under the assumption that
the EXTENT and UNITS parameters in the mapfile would define the
coordinates of the source image but perhaps that is only constraining
the output?
If that is the case, how can I go about providing georeference for an
image such as that?
Kevin
