[mapserver-users] Re: Two Layers not matching up when one is
reprojected
Matt Pettis
matthew.pettis at gmail.com
Thu Nov 10 00:59:20 EST 2011
That worked perfectly, thank you!
Just for posterity, is there an explanation you know of why the
spatialreference.org proj4 parameters didn't work? I took the fact that I
could exchange epsg:3857 with epsg:900913 from the book "OpenLayers 2.10",
but it appears that it doesn't work...
Thanks a ton again for your help!
Matt
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Two-Layers-not-matching-up-when-one-is-reprojected-tp6980480p6980632.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
