[mapserver-users] GAP problem on MapServer 6.0.1
Jackey Cheung
cheung.jackey at gmail.com
Thu Nov 10 20:03:59 EST 2011
Thanks for your comment, Havard Tveite.
As you suspected, the strange position (and also redundant) of arrows
is problem in figure 1. Since there is only one line there, we expect
only one set of (around 2~3) arrows were rendered. We can't figure out
why there are redundant arrows rendered at strange positions. The
expected outcome is only 2~3 arrows shall be rendered right around the
center of the line.
On Thu, Nov 10, 2011 at 4:49 PM, Havard Tveite <havard.tveite at umb.no> wrote:
> Dear Jackey Cheung,
> I am not sure what exactly you are trying to achieve.
> Your arrows seem to point in the direction of the lines.
> The topmost arrow in figure 1 is placed at a strange
> position - is that the problem?
> Some comments:
> The result shown in image 2 is expected. The arrow
> symbols are in this case placed at the start points of
> the lines according to the centre point of the symbol's
> bounding rectangle (except 0,0 is always taken as the
> upper left corner of the bounding rectangle).
> When using a negative GAP, the direction of the symbol
> is the direction of the line at the (end)point.
> In version 6.2, ANCHORPOINT is introduced to make it
> possible to specify a different anchor point for the
> symbol (http://mapserver.org/trunk/mapfile/symbol.html).
> The centre point of the bounding box of your arrow_right
> symbol will be at (17.5,7) in the symbol's coordinate
> system, so the arrows will be placed somewhat shifted to
> the right (in the direction of the arrow).
> In 6.0, if you want the ends of the arrows to be aligned
> with the start of the lines (when using geomtransform
> start), you could use the following symbol:
> SYMBOL
> NAME "arrow_right_shift"
> TYPE VECTOR
> POINTS
> 30 6
> 52 6
> 50 0
> 60 7 # why 7.5?
> 50 14
> 52 8
> 30 8
> 30 6
> END
> FILLED TRUE
> END
> In 6.2, you will be able to specify this using
> ANCHORPOINT 1 0.5
> Håvard
> On 11/10/2011 06:35 AM, Jackey Cheung wrote:
>> Hi all,
>> We are trying to render line direction on 6.0.1. However, there are
>> something weird with it.
>> SYMBOL
>> NAME "arrow_right"
>> TYPE VECTOR
>> POINTS
>> 5 6
>> 27 6
>> 25 0
>> 35 7.5
>> 25 14
>> 27 8
>> 5 8
>> 5 6
>> END
>> FILLED TRUE
>> END
>> LAYER
>> NAME "traffic_direction"
>> STATUS DEFAULT
>> TYPE LINE
>> MAXSCALEDENOM 5000
>> CONNECTIONTYPE POSTGIS
>> PROCESSING "CLOSE_CONNECTION=DEFER"
>> CONNECTION "host=xxxxxxx dbname=******* user=xxxxxxxxxx
>> password=************"
>> DATA "geom FROM view_render_traffic_direction USING
>> UNIQUE oid USING SRID=4326"
>> CLASS
>> NAME "Traffic Direction"
>> STYLE
>> ANGLE AUTO
>> SYMBOL "arrow_right"
>> SIZE 6
>> COLOR 0 0 250
>> GAP -200
>> #GEOMTRANSFORM "start"
>> END
>> END
>> END
>> The layer above is rendered as 1.PNG. We've checked that there are
>> only one line (ring) there, but arrows are rendered problematic.
>> Then we've tried to change GEOMTRANSFORM to "start" or "end", then
>> rings seem OK, but all arrows at intersections got crossed, as 2.PNG.
>> We've also tried to use OFFSET and GAP with positive and negative
>> combinations, but none can solve the problem.
>> Can anyone shed some light for us? Thanks in advance.
> mapserver-users at lists.osgeo.org
