[mapserver-users] Raster image performance
Frank Warmerdam
warmerdam at pobox.com
Fri Nov 11 14:51:35 EST 2011
Ian,
I am guessing you actually have many files, not just one big
one. Is that right? As you zoom out opening many files to
accumulate the full image is expensive. Up to some scale
it is practical to merge things into one big mosaic tiff with overviews.
At some point that can be impractically large.
The usual practice to avoid opening too many files with tileindexed
layers is to have two LAYERs in your map file. One for the fuller
resolution data, and then another at greatly reduced resolution
and then to generate a reduced resolution mosaic for the reduced
resolution layer. Use the MIN/MAX SCALE control keyword in the
LAYER to control which is used.
Best regards,
On Fri, Nov 11, 2011 at 11:15 AM, Ian Walberg <ian.walberg at airborne.aero> wrote:
> Does anyone have any experience of how to get the best performance out
> of raster formats.
> We have an application which needs to be able to display a number of
> zoom levels and once we get out to whole earth or continent level the
> performance is poor. Our assumption is that it is the shrinking of the
> images which where is the time if being used up.
> The raster files are tifs with external world files, adding overviews
> helps a little.
> The zoom levels and output resolution can be fixed so if the overviews
> match exactly the required image size that look like it would work but
> we cannot see how to do this.
> So any advice on what are the most efficient file formats to open and
> the most efficient output format.
> The application is written in php mapscript which runs as a service and
> not via a browser.
> Thanks
> Ian
> mapserver-users at lists.osgeo.org
and watch the world go round - Rush | Geospatial Software Developer
