[mapserver-users] Problem with Variable Substitution for EXPRESSION
Daniel Morissette dmorissette at mapgears.com
Wed Nov 16 07:44:23 PST 2011
Which binaries are you using?
If you your own custom build then are you sure it's not a case of
multiple versions of REGEX on the same system? That used to be a problem
in the old days with PHP's local copy of regex conflicting with the
system regex, but I don't think that is a problem any more though.
On 11-11-16 10:40 AM, Lime, Steve D (DNR) wrote:
> Well, that’s not good is it. Hmmm… I ran a quick test here using this
> mapfile:
> MAP
> NAME 'test'
> SIZE 450 600
> EXTENT 125000 4785000 788000 5489000
> IMAGETYPE PNG8
> LAYER
> VALIDATION
> 'area' '^[-+]?[0-9]*\.?[0-9]+$'
> END
> NAME 'county'
> STATUS DEFAULT
> TYPE POLYGON
> DATA ' bdry_counpy2'
> CLASS
> EXPRESSION ([area] > %area%)
> STYLE COLOR 212 212 212 OUTLINECOLOR 0 0 0 END
> END
> END
> END
> This is against 6.0 latest trunk although I don’t think there have been
> any changes in that area…
> I can run something like:
> If ‘area’ parameter is provided as a non-double then the substitution
> isn’t done. I believe the substitution validation errors fail silently.
> This example works, how different is what you’re doing?
> Steve
> *From:*Prabu Raja [mailto:prab.raja at gmail.com]
> *Sent:* Wednesday, November 16, 2011 5:16 AM
> *To:* Lime, Steve D (DNR)
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Problem with Variable Substitution for
> EXPRESSION
> Thanks Steve.
> Tried the following regular expression
> "[-+]?[0-9]*\.?[0-9]+".
> For which the internal server error is coming from Apache. No error
> logged in mapserver log.
>   "Internal Server Error
> The server encountered an internal error or misconfiguration and was
> unable to complete your request.*"*
> On Tue, Nov 15, 2011 at 8:37 PM, Lime, Steve D (DNR)
> <Steve.Lime at state.mn.us <mailto:Steve.Lime at state.mn.us>> wrote:
> See http://www.regular-expressions.info/floatingpoint.html for some good
> examples.
> Steve
> *From:*mapserver-users-bounces at lists.osgeo.org
> <mailto:mapserver-users-bounces at lists.osgeo.org>
> [mailto:mapserver-users-bounces at lists.osgeo.org
> <mailto:mapserver-users-bounces at lists.osgeo.org>] *On Behalf Of *Prabu Raja
> *Sent:* Tuesday, November 15, 2011 4:29 AM
> *To:* mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> *Subject:* [mapserver-users] Problem with Variable Substitution for
> EXPRESSION
> Hi,
> I need to compare one attribute from database table in "EXPRESSION"
> (under "LAYER") with six different values passed as Variable
> Substitution for coloring the layer.
> I did added validation for those variables in the map file, but for some
> reason I am getting the below error.
> *msValidateParameter(): Regular expression error. Parameter pattern
> validation failed.*
> *msEvalRegex(): Regular expression error. String failed expression test.*
> validation failed.*
> Could anyone help me with where I am wrong? Below is the map file
> content for this layer.
> All the six variables would be numbers (may be a decimal number), Is my
> regular expression correct?
> WEB
> VALIDATION
> value_one "^[\d+(\.\d)]*$"
> value_two "^[\d+(\.\d)]*$"
> value_three "[^\d+(\.\d)]*$"
> value_four "[^\d+(\.\d)]*$"
> value_five "[^\d+(\.\d)]*$"
> value_six "[^\d+(\.\d)]*$"
> END
> END
> LAYER
> NAME "state"
> TYPE polygon
> STATUS ON
> CONNECTIONTYPE POSTGIS
> CONNECTION "user=postgres password=****** dbname=shpdb host=localhost
> port=5432"
> DATA "the_geom FROM (SELECT gid, the_geom, totpop1 FROM state_shape) AS
> SUBQUERY using unique gid"
> PROCESSING "CLOSE_CONNECTION=DEFER"
> CLASSITEM "totpop1"
> OPACITY 100
> CLASS
> EXPRESSION ([TOTPOP1] >= %value_one% AND [TOTPOP1] < %value_two%)
> STYLE
> COLOR 255 108 118
> OUTLINECOLOR 255 255 255
> END
> END
> CLASS
> EXPRESSION ([TOTPOP1] >= %value_two% AND [TOTPOP1] < %value_three%)
> STYLE
> COLOR 254 189 75
> END
> END
> CLASS
> EXPRESSION ([TOTPOP1] >= %value_three% AND [TOTPOP1] < %value_four%)
> STYLE
> COLOR 254 247 46
> END
> END
> CLASS
> EXPRESSION ([TOTPOP1] >= %value_four% AND [TOTPOP1] < %value_five%)
> STYLE
> COLOR 39 251 114
> END
> END
> CLASS
> EXPRESSION ([TOTPOP1] >= %value_five% AND [TOTPOP1] <= %value_six%)
> STYLE
> COLOR 108 111 205
> END
> END
> END
> Regards,
> Prabu Raja
> Regards,
> Prabu Raja
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
More information about the MapServer-users mailing list
