[mapserver-users] Re: QGis 'Zoom to best scale' Not Working
SixDegrees
paulcarlisle at comcast.net
Tue Nov 22 06:08:42 EST 2011
Sorry, I was wrong in the previous message; the resx and resy settings do
show up in the capabilities document. They make no difference, however; the
bounding box requested by QGis is still in error.
SixDegrees wrote
> Thank you. I added wms_resx and wms_resy to my mapfile with reasonable
> values (and some unreasonable ones, just as tests). This makes no
> difference. When I make a GetCapabilities request, the layer's bounding
> box is correct but it does NOT contain the resx or resy settings, as I
> believe it should.
> I don't know if this is a problem in my mapfile or in MapServer. My
> mapfile layer looks like this (file names changed for proprietary
> reasons):
> LAYER
> NAME "MyImage"
> GROUP "MyGroup"
> EXTENT 75.80425 35.304 76.01625 35.476
> METADATA
> "wms_title" "MyImage"
> "wms_group_title" "MyGroup"
> "wms_extent" "75.80425 35.304 76.01625 35.476"
> "wms_srs" "EPSG:4326"
> "wms_resx" "1.0" # Note: these values are for testing only. The
> actual values have
> "wms_resy" "1.0" # also been tried, with no success. They are
> 5.90139233796e-06, -4.85244300668e-06
> END
> PROCESSING "SCALE=AUTO"
> PROCESSING "SCALE_BUCKETS=256"
> TYPE RASTER
> DATA "MyImage.vrt"
> PROJECTION
> "+proj=longlat +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +no_defs"
> END
> END
> Rahkonen Jukka wrote
>> Hi,
>> WMS does not advertise by default the native resolution of the data. I
>> have never tried but perhaps adding wms_resx, wms_resy metadata into
>> layer metadata would add that information into GetCapabilities
>> http://mapserver.org/ogc/wms_server.html.
>> I do not know if QGis can utilise that information even if it exists.
>> -Jukka Rahkonen-
>> SixDegrees wrote:
>>> I'm not sure if this is a QGis problem or a problem with my
>> Mapserver-generated WMS layer. When I load a WMS image in QGis,
>> everything
>> works as expected except when I select 'Zoom to best scale' I get a
>> Mapserver error stating that the bounding box is illegal. And it is - the
>> bounding box corner points in the getmap request are identical. This
>> selections is supposed to zoom in so the pixels displayed are 1:1 or 100%
>>> A look at the capabilities request returned by Mapserver and the mapfile
>>> and
>> images involved don't show anything obviously wrong. Is it possible that
>> QGis is sending the wrong request? Or is something missing from either
>> the
>> capabilities document or the mapfile layer?
>>> I'm not really sure where to start looking to isolate the problem. Note
>>> that
>> if I load images directly instead of through Mapserver WMS I am able to
>> zoom
>> to scale without any problem, which suggests a problem with Mapserver,
>> likely in the mapfile. I am using VRT files as intermediaries between the
>> Mapfile and the underlying NITF files; it seems that Mapserver should be
>> using the affine transform contained in the VRT to determine proper
>> scaling,
>> but I'm not sure if that is sufficient. Are there arguments that need to
>> be
>> placed in the Mapfile metadata to help WMS generation along? Or something
>> that would cause items in the capabilities document to be left out?
>>> Using QGis 1.7.0 on Linux.
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/QGis-Zoom-to-best-scale-Not-Working-tp7017776p7017776.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> mapserver-users at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
View this message in context: http://osgeo-org.1803224.n2.nabble.com/QGis-Zoom-to-best-scale-Not-Working-tp7017776p7020066.html
