[mapserver-users] I am having a problem using
processQueryTemplate...
boesiii
boesiii at yahoo.com
Wed Nov 30 12:51:09 EST 2011
I am trying to diagnose why processQueryTemplate is not returning any values.
Below is part of the relevant code:
$results = $map->processquerytemplate(array(), false);
I am using MapServer 5.6.6 and GeoMoose 2.4. Below is part of my MAP file:
METADATA
'itemquery' 'ftma_waterlines_itemquery.html'
'itemquery-filter' '/.*[qstring].*/i'
'qstring_validation_pattern' '.'
END
Does the processQueryTemplate method work correctly in 5.6.6? I found this
http://www.osgeo.org/pipermail/mapserver-dev/2010-April/009935.html which
talks about processQueryTemplate being broken.
Does someone have an easy example of how to use processQueryTemplate, so
that I can better understand how the method is supposed to work?
Thanks
Ed
View this message in context: http://osgeo-org.1803224.n2.nabble.com/I-am-having-a-problem-using-processQueryTemplate-tp7047793p7047793.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
