[mapserver-users] tileindex shptree
Eric Weisbender
Weisbend at wapa.gov
Mon Oct 31 10:10:56 EDT 2011
Hello,
After further investigation of this tileindex error issue I have seemed to narrow it down to the query map not being able to resolve something with the tileindex. If I comment the query map definition out then all queries of the tileindex work fine. I'm not sure if this is a bug or an issue with my query map definition. Advice and/or comments would be greatly appreciated.
Thanks
EW
>>> On 10/28/2011 at 3:31 PM, in message <CA+YzLBdmmvztPpkRL1D=u5gc09zHDYO_7HmYDrWEUUOyJai1_w at mail.gmail.com>, Frank Warmerdam <warmerdam at pobox.com> wrote:
Eric,
Do things fail consistently fora given request? I would be
willing to do some examination of this problem this evening
(pacific time) if you can provide a canned demonstration of
the issue (mapfile+tileindex+query). I should be able to fake
the data referred to by the tileindex if necessary.
I don't feel that adding a spatial index (.qix) is the right
solution. Something is either wrong with your tileindex
or with mapserver (IMHO).
Best regards,
On Fri, Oct 28, 2011 at 2:09 PM, Eric Weisbender <Weisbend at wapa.gov> wrote:
> Hello,
> We are using a tileindex layer to draw multiple county parcel data layers.
> For some reason the query of these layers is either hit or miss. Sometimes
> it returns a query. Other times a query returns "Invalid field index 0"
> from the error file defined in the mapfile. And the third query result I'm
> getting is "Internal Server Error" from I assume apache. These results are
> all on the same data indexed by this one tileindex layer. Would it help if
> I built a shptree qix file and do I just do that for the tileindex file or
> all file the tileindex file is pointing to. I have wasted two day's on this
> and am completely open to any and all idea's. Thanks in advance.
> EW
> mapserver-users at lists.osgeo.org
and watch the world go round - Rush | Geospatial Software Developer
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111031/f6984ec1/attachment.html
