[mapserver-users] got error in some pmapper_demodata as WMS
goldalworming
ariefnurandono at gmail.com
Mon Oct 31 20:15:59 EDT 2011
hi, I'm learning open layer and tried to use map server as wms service in my
ubuntu
in pmapper_demodata, 3 layers exist : countries, cities1000eu and rivers
my error log shows this error while I tried to accesing cities1000eu layers
but works fine in countries and rivers layer
[Tue Nov 1 07:03:56 2011].166194 msWMSLoadGetMapParams(): WMS server error.
Invalid layer(s) given in the LAYERS parameter.
this is the mapfile
LAYER
NAME "countries"
TYPE polygon
DATA "countries"
TRANSPARENCY 30
TEMPLATE void
PROJECTION
#"init=epsg:4326"
"+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs no_defs"
END
METADATA
"DESCRIPTION" "Countries"
## ADAPTED TO MULTILINGUAL SHAPEFILE
"RESULT_FIELDS"
"ISOCODE, at default:NAME_EN at de:NAME_DE at it:NAME_IT at fr:NAME_FR at br:NAME_BR at es:NAME_ES, at default:CAPITAL_EN at de:CAPITAL_DE at it:CAPITAL_IT at fr:CAPITAL_FR at br:CAPITAL_BR at es:CAPITAL_ES,AREA_KM2,POPULATION"
"RESULT_HEADERS" "ISO Code,Name,Capital,Area,Population"
"ows_title" "countries"
"ows_enable_request" "*"
"wms_srs" "EPSG:4326 EPSG:4030"
END # Metadata
CLASS
Name 'Countries'
COLOR 200 254 199
OUTLINECOLOR 0 0 0
END # Class
END # Layer
LAYER
NAME "cities10000eu"
TYPE point
DATA "cities10000eu"
TOLERANCE 6
TOLERANCEUNITS pixels
LABELITEM "NAME"
LABELMAXSCALE 8000000
TEMPLATE void
PROJECTION
#"init=epsg:4326"
END
METADATA
"DESCRIPTION" "Cities"
"RESULT_FIELDS" "NAME, ISO2_CODE, POPULATION, GTOPO30"
"RESULT_HEADERS" "Name,Country,Inhabitants,Altitude"
"RESULT_HYPERLINK" "NAME"
"LAYER_ENCODING" "UTF-8"
"ows_title" "cities1000"
END # Metadata
CLASS
NAME "> 1'000'000"
EXPRESSION ([POPULATION] > 1000000)
COLOR 255 0 0
OUTLINECOLOR 0 0 0
SYMBOL 'square'
SIZE 9
LABEL
POSITION Auto
COLOR 0 0 150
BUFFER 2
TYPE truetype
ENCODING "UTF-8"
FONT FreeSans
SIZE 8
MAXSIZE 9
#SIZE small
END #Label
END # Class
CLASS
NAME "500'000 - 1'000'000"
EXPRESSION ([POPULATION] <= 1000000 AND [POPULATION] > 500000)
COLOR 255 0 0
SYMBOL 'circle'
SIZE 8
LABEL
POSITION Auto
COLOR 0 0 150
BUFFER 2
TYPE truetype
ENCODING "UTF-8"
FONT FreeSans
SIZE 8
MAXSIZE 9
#SIZE small
END #Label
END # Class
CLASS
NAME "100'000 - 500'000"
EXPRESSION ([POPULATION] <= 500000 AND [POPULATION] > 100000)
COLOR 255 0 0
SYMBOL 'square'
SIZE 5
END # Class
CLASS
NAME "50'000 - 100'000"
EXPRESSION ([POPULATION] <= 100000 AND [POPULATION] > 50000)
COLOR 0 0 0LAYER
NAME "countries"
TYPE polygon
DATA "countries"
TRANSPARENCY 30
TEMPLATE void
PROJECTION
#"init=epsg:4326"
END
METADATA
"RESULT_FIELDS"
END # Metadata
CLASS
Name 'Countries'
COLOR 200 254 199
OUTLINECOLOR 0 0 0
END # Class
END # Layer
LAYER
TYPE point
TOLERANCE 6
LABELITEM "NAME"
TEMPLATE void
PROJECTION
#"init=epsg:4326"
END
METADATA
END # Metadata
CLASS
NAME "> 1'000'000"
COLOR 255 0 0
OUTLINECOLOR 0 0 0
SYMBOL 'square'
SIZE 9
LABEL
POSITION Auto
COLOR 0 0 150
BUFFER 2
TYPE truetype
ENCODING "UTF-8"
FONT FreeSans
SIZE 8
MAXSIZE 9
#SIZE small
END #Label
END # Class
CLASS
COLOR 255 0 0
SYMBOL 'circle'
SIZE 8
LABEL
POSITION Auto
COLOR 0 0 150
BUFFER 2
TYPE truetype
ENCODING "UTF-8"
FONT FreeSans
SIZE 8
MAXSIZE 9
#SIZE small
END #Label
END # Class
CLASS
COLOR 255 0 0
SYMBOL 'square'
SIZE 5
END # Class
CLASS
COLOR 0 0 0
SYMBOL 'square'
SIZE 4
#MAXSCALE 20000000
END # Class
CLASS
NAME "10'000 - 50'000"
EXPRESSION ([POPULATION] <= 50000 AND [POPULATION] > 10000)
COLOR 100 100 100
SYMBOL 'circle'
SIZE 3
#MAXSCALE 10000000
END # Class
END # Layer
# Start of Layer Rivers.shp
LAYER
NAME "rivers"
TYPE line
DATA "rivers"
TOLERANCE 3
TEMPLATE void
PROJECTION
#"init=epsg:4326"
END
METADATA
"DESCRIPTION" "Rivers"
"RESULT_FIELDS" "NAME"
"RESULT_HEADERS" "Name"
"ows_title" "cities"
END # Metadata
CLASS
Name 'Rivers'
COLOR 0 0 255
END # Class
END # Layer
SYMBOL 'square'
SIZE 4
#MAXSCALE 20000000
END # Class
CLASS
COLOR 100 100 100
SYMBOL 'circle'
SIZE 3
#MAXSCALE 10000000
END # Class
END # Layer
LAYER
NAME "rivers"
TYPE line
DATA "rivers"
TOLERANCE 3
TEMPLATE void
PROJECTION
#"init=epsg:4326"
END
METADATA
END # Metadata
CLASS
Name 'Rivers'
COLOR 0 0 255
END # Class
END # Layer
I hope any body could help.
Regards
View this message in context: http://osgeo-org.1803224.n2.nabble.com/got-error-in-some-pmapper-demodata-as-WMS-tp6950236p6950236.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
