VS: [mapserver-users] WMS/WFS Mapserver Projection Error
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Sep 5 06:37:45 EDT 2011
Your failing client is most probably sending WFS 1.1.0 version GetFeature request and therefore Mapserver is sending the coordinates in Latitude-Longitude order. This is how the WFS 1.1.0 says it should be. According to the WFS 1.1.0 standard your client is doing it wrong. Lots of people have said that the WFS 1.1.0 standard is stupid.
If your client supports WFS 1.0.0 use that and the map will look good. Have a try with your browser and you will see what I mean
http://your_server/cgi-bin/mapserv?service=WFS&version=1.0.0&request=GetFeature&typeName=your_typename&maxFeatures=1&map=your_mapfile
http://your_server/cgi-bin/mapserv?service=WFS&version=1.1.0&request=GetFeature&typeName=your_typename&maxFeatures=1&map=your_mapfile
-Jukka Rahkonen-
Lucho wrote:
Hi List,
I have a problem with some data when I'm publishing a WMS and then, publish the same data in a WFS service. Everithing is ok speaking about attending requests, but when I get the data with some clients, it seems that WFS has a total different projection.
The image attached explain better the situation.
In Quantum GIS the two services working well, but in other clients I have this problem. The data are in EPSG:4326
Any ideas?
Best regards,
LUIS FERNANDO ORTIZ REYES
INGENIERO DE SISTEMAS
UNIVERSIDAD DISTRITAL
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110905/bc6d02eb/attachment.html
