[mapserver-users] msQueryByFilter(): Search returned no results.
Steve Lime
sdlime at gmail.com
Mon Sep 5 08:28:10 EDT 2011
You could try defining a smaller bbox in lat/lon,something tighter to your
actual AOI. -Steve
2011/9/5 Michal Šrédl <michal.sredl at gmail.com>:
> Hi Steve,
> may be you are right, because when I replace epsg:102067 with
> epsg:3035 it works fine
> Cheers,
> Michal
> 2011/8/29 Steve Lime <sdlime at gmail.com>:
>> Looking at the code the correct projection work is done. I wonder if
>> there's something funky projecting the globe (-180 -90 180 90) to
>> epsg:102067.
>> Steve
>> 2011/8/26 Steve Lime <sdlime at gmail.com>:
>>> Ok, definitely a bug here... Will take a look. Steve
>>> 2011/8/26 Michal Šrédl <michal.sredl at gmail.com>:
>>>> Hi Steve,
>>>> for epsg:4326 and url
>>>> http://localhost//cgi-bin/ows?mode=itemnquery&qlayer=typ&qitem=zver&qstring=2
>>>> it says
>>>> msQueryByAttributes(): Search returned no results. No matching
>>>> record(s) found, layer and area of interest do not overlap.
>>>> Cheers,
>>>> Mike
>>>>> You must have a default mapfile set in apache, that's cool. Use the second URL.
>>>>> Change qstring_validation to qstring_validation_pattern from my first
>>>>> message, my mistake.
>>>>> Steve
>>>>>> Hi Steve,
>>>>>> regardless of the projection settings, I get the following result:
>>>>>> For
>>>>>> http://localhost//cgi-bin/ows?map=mapfile&mode=itemnquery&qlayer=typ&qitem=zver&qstring=2
>>>>>> I see
>>>>>> msLoadMap(): Regular expression error. MS_DEFAULT_MAPFILE_PATTERN
>>>>>> validation failed. msEvalRegex(): Regular expression error. String
>>>>>> failed expression test.
>>>>>> And for
>>>>>> I see
>>>>>> mapserv(): Web application error. Parameter 'qstring' value fails to
>>>>>> validate. msValidateParameter(): Regular expression error. Parameter
>>>>>> pattern validation failed.
>>>>>> Cheers,
>>>>>> Michal
>>>>>>> I would agree this sounds like a bug. The map extent *should* be
>>>>>>> projected to the layer extent and that's what's used to identify
>>>>>>> candidate features. Can you check what happens with a native mapserver
>>>>>>> attribute query in this case? If possible try this:
>>>>>>> 1) set your MAP projection back to geographic, and restore your
>>>>>>> geographic map extent.
>>>>>>> 2) add this line to the layer metadata 'qstring_validation' '^[0-9]$'
>>>>>>> 3) go to the following URL:
>>>>>>> http://localhost//cgi-bin/ows?map=[yourmapfile]&mode=itemnquery&qlayer=typ&qitem=zver&qstring=2
>>>>>>> and see what happens.
>>>>>>> This will run a different query function msQueryByAttributes() that's
>>>>>>> not new to 6.0.x.
>>>>>>> Steve
>>>>>>>> Hi Jukka,
>>>>>>>> the current settings returns expected result with &srsName=EPSG:4326
>>>>>>>> as well. The original settings doesn't work neither with
>>>>>>>> &srsName=EPSG:4326 nor &srsName=EPSG::102067.
>>>>>>>> Yes, it looks like there would be a problem in case of several WFS
>>>>>>>> layers with different projections of the source data.
>>>>>>>> Cheers,
>>>>>>>> Mike
>>>>>>>> 2011/8/26 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>:
>>>>>>>>> Hi,
>>>>>>>>> Good that you could make it to work. However, this feels maybe like a bug if it means that using ogc:PropertyIsEqualTo filter without any other filter works only if projection of the source data is the same than the default output projection from WFS.
>>>>>>>>> Could you have one more trial with the original settings and see if adding &srsName=EPSG:4326 or &srsName=EPSG::102067 is changing anything? And also if your current setting gives correct result with &srsName=EPSG:4326.
>>>>>>>>> -Jukka Rahkonen.
>>>>>>>>> Michal Šrédl wrote:
>>>>>>>>>> Hi all,
>>>>>>>>>> problem solved. I needed to set:
>>>>>>>>>> EXTENT -905000 -1230000 -400000 -900000
>>>>>>>>> and
>>>>>>>>> PROJECTION
>>>>>>>>> ## "init=epsg:4326"
>>>>>>>>> "init=epsg:102067"
>>>>>>>>> END
>>>>>>>>> (Epsg 102067 is the projection of the layer being filtered.)
>>>>>>>>> Thank you very much again,
>>>>>>>>> Michal
>>>>>>>>> 2011/8/25 Michal Šrédl <michal.sredl at gmail.com>:
>>>>>>>>>> Hi Steve,
>>>>>>>>>> Thanks a lot. The extent should be large enough to encompass all the
>>>>>>>>>> features. Here comes the whole mapfile:
>>>>>>>>>> MAP
>>>>>>>>>> NAME "MIS WFS Server"
>>>>>>>>>> STATUS ON
>>>>>>>>>> SIZE 500 500
>>>>>>>>>> EXTENT -180 -90 180 90
>>>>>>>>>> SHAPEPATH "data/"
>>>>>>>>>> IMAGECOLOR 255 255 255
>>>>>>>>>> CONFIG MS_ERRORFILE "log/mapserv.log"
>>>>>>>>>> DEBUG 5
>>>>>>>>>> WEB
>>>>>>>>>> IMAGEPATH "/var/www/tmp/"
>>>>>>>>>> IMAGEURL "/tmp/"
>>>>>>>>>> METADATA
>>>>>>>>>> "wfs_title" "MIS WFS Server" ## REQUIRED
>>>>>>>>>> "wfs_onlineresource" "http://127.0.0.1/cgi-bin/ows?"
>>>>>>>>>> "wfs_srs" "EPSG:4326 EPSG:102067"
>>>>>>>>>> "wms_srs" "EPSG:4326 EPSG:102067" ## Recommended
>>>>>>>>>> "wcs_srs" "EPSG:4326 EPSG:102067" ## Recommended
>>>>>>>>>> "ows_enable_request" "*"
>>>>>>>>>> "ows_updatesequence" "2011-29-05T00:24:00"
>>>>>>>>>> END
>>>>>>>>>> END
>>>>>>>>>> PROJECTION
>>>>>>>>>> "init=epsg:4326"
>>>>>>>>>> END
>>>>>>>>>> LAYER
>>>>>>>>>> NAME "typ"
>>>>>>>>>> METADATA
>>>>>>>>>> "wfs_title" "Typologie" ## REQUIRED
>>>>>>>>>> "wfs_include_items" "all"
>>>>>>>>>> "gml_featureid" "CISLO" ## REQUIRED
>>>>>>>>>> "gml_include_items" "all" ## Optional (serves all attributes for layer)
>>>>>>>>>> "gml_types" "auto"
>>>>>>>>>> "gml_geometries" "msGeometry"
>>>>>>>>>> "gml_msGeometry_type" "polygon"
>>>>>>>>>> END
>>>>>>>>>> DATA typ.shp
>>>>>>>>>> TYPE POLYGON
>>>>>>>>>> STATUS ON
>>>>>>>>>> PROJECTION
>>>>>>>>>> "init=epsg:102067"
>>>>>>>>>> END
>>>>>>>>>> DUMP TRUE ## REQUIRED
>>>>>>>>>> CLASS
>>>>>>>>>> NAME "Typ"
>>>>>>>>>> STYLE
>>>>>>>>>> COLOR 0 0 155
>>>>>>>>>> OUTLINECOLOR 120 120 120
>>>>>>>>>> END
>>>>>>>>>> TEMPLATE "templates/typ_zver.html"
>>>>>>>>>> END
>>>>>>>>>> DEBUG 5
>>>>>>>>>> END # Layer
>>>>>>>>>> LAYER
>>>>>>>>>> NAME "hsrs"
>>>>>>>>>> TYPE RASTER
>>>>>>>>>> STATUS ON
>>>>>>>>>> CONNECTION "http://www.bnhelp.cz/cgi-bin/crtopo?"
>>>>>>>>>> DEBUG ON
>>>>>>>>>> CONNECTIONTYPE WMS
>>>>>>>>>> METADATA
>>>>>>>>>> "wms_srs" "EPSG:4326"
>>>>>>>>>> "wms_name" "obce,kraje,hr_cr,sidla,doprava"
>>>>>>>>>> "wms_title" "CR Topo"
>>>>>>>>>> "wms_server_version" "1.1.1"
>>>>>>>>>> "wms_format" "image/png"
>>>>>>>>>> "wms_latlonboundingbox" "11.9384 48.2337 18.957 51.3549"
>>>>>>>>>> END
>>>>>>>>>> END
>>>>>>>>>> END # Map File
>>>>>>>>>> Cheers,
>>>>>>>>>> Michal
>>>>>>>>>> 2011/8/25 Steve Lime <sdlime at gmail.com>:
>>>>>>>>>>> What is your default EXTENT set to in your mapfile? It should be large enough to encompass all features. - Steve
>>>>>>>>>>> Sent from my iPad
>>>>>>>>>>> On Aug 24, 2011, at 7:58 AM, Michal Šrédl <michal.sredl at gmail.com> wrote:
>>>>>>>>>>>> Hi all,
>>>>>>>>>>>> I am trying to use FES filter for WFS layer and get no result, even
>>>>>>>>>>>> thought I should get one.
>>>>>>>>>>>> In my browser, I request
>>>>>>>>>>>> http://localhost//cgi-bin/ows?&REQUEST=GetFeature&VERSION=1.1.0&SERVICE=WFS&TYPENAME=typ&FILTER=<ogc:Filter
>>>>>>>>>>>> xmlns:ogc="http://www.opengis.net/ogc"><ogc:PropertyIsEqualTo><ogc:PropertyName>ZVER</ogc:PropertyName><ogc:Literal>2</ogc:Literal></ogc:PropertyIsEqualTo></ogc:Filter>
>>>>>>>>>>>> and get
>>>>>>>>>>>> <wfs:FeatureCollection
>>>>>>>>>>>> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>>>>>>>>>>>> xmlns:gml="http://www.opengis.net/gml"
>>>>>>>>>>>> xmlns:wfs="http://www.opengis.net/wfs"
>>>>>>>>>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>>>>>>>>>> xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver
>>>>>>>>>>>> http://127.0.0.1/cgi-bin/ows?SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=typ&OUTPUTFORMAT=text/xml;%20subtype=gml/3.1.1
>>>>>>>>>>>> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
>>>>>>>>>>>> <gml:boundedBy>
>>>>>>>>>>>> <gml:Null>missing</gml:Null>
>>>>>>>>>>>> </gml:boundedBy>
>>>>>>>>>>>> </wfs:FeatureCollection>
>>>>>>>>>>>> even though I do know, that features with ZVER=2 do exist.
>>>>>>>>>>>> In the mapserver log file, I get
>>>>>>>>>>>> [Wed Aug 24 14:48:52 2011].296607 msQueryByFilter(): Search returned
>>>>>>>>>>>> no results. No matching record(s) found.
>>>>>>>>>>>> [Wed Aug 24 14:48:52 2011].296747 mapserv request processing time
>>>>>>>>>>>> (msLoadMap not incl.): 0.002s
>>>>>>>>>>>> [Wed Aug 24 14:48:52 2011].296764 msFreeMap(): freeing map at 0x2783120.
>>>>>>>>>>>> [Wed Aug 24 14:48:52 2011].296773 freeLayer(): freeing layer at 0x278b570.
>>>>>>>>>>>> I have checked http://mapserver.org/errors.html#id2 with similar error
>>>>>>>>>>>> "msQueryByPoint: search returned no results" and tried to create a
>>>>>>>>>>>> simple template:
>>>>>>>>>>>> <!-- MapServer Template -->
>>>>>>>>>>>> <tr>
>>>>>>>>>>>> <td>[lrn]</td>
>>>>>>>>>>>> <td>[ZVER]</td>
>>>>>>>>>>>> </tr>
>>>>>>>>>>>> but with no effect.
>>>>>>>>>>>> In the mapfile, there is
>>>>>>>>>>>> LAYER
>>>>>>>>>>>> NAME "typ"
>>>>>>>>>>>> METADATA
>>>>>>>>>>>> "gml_types" "auto"
>>>>>>>>>>>> END
>>>>>>>>>>>> DATA typ.shp
>>>>>>>>>>>> TYPE POLYGON
>>>>>>>>>>>> STATUS ON
>>>>>>>>>>>> PROJECTION
>>>>>>>>>>>> "init=epsg:102067"
>>>>>>>>>>>> END
>>>>>>>>>>>> CLASS
>>>>>>>>>>>> NAME "Typ"
>>>>>>>>>>>> STYLE
>>>>>>>>>>>> COLOR 0 0 155
>>>>>>>>>>>> END
>>>>>>>>>>>> END
>>>>>>>>>>>> DEBUG 5
>>>>>>>>>>>> END # Layer
>>>>>>>>>>>> What is wrong with my FES filter? How can I make it to run?
>>>>>>>>>>>> Thanks a lot,
>>>>>>>>>>>> Michal
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> mapserver-users mailing list
>>>>>>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
