[mapserver-users] Re: MapScript WMS request
Mr. Puneet Kishor
punk.kish at gmail.com
Thu Sep 8 12:27:40 EDT 2011
On Sep 7, 2011, at 10:29 PM, Frank Warmerdam wrote:
> On 11-09-07 08:18 PM, Mr. Puneet Kishor wrote:
>> I would really appreciate insight from someone well-versed in the ins and outs of WMS via MapScript. Looking at the discussion at [http://trac.osgeo.org/mapserver/ticket/670], the `img = wms_map.draw()` step seems to be a crucial part of drawing the image.
>> So, I added `my $img = $map->draw();` to my code below, and indeed, the image was drawn and sent back to the browser.
>> Is this something that should be added to the examples in the documentation? Is this the right way to do things? In any case, I am not write to STDOUT, and sending the buffer directly. Instead, my code is very much like a regular request (and it works) --
>> my $new_extent = $map->{extent};
>> my $req = new mapscript::OWSRequest();
>> $req->setParameter( "SERVICE", "WMS" );
>> $req->setParameter( "VERSION", "1.1.0" );
>> $req->setParameter( "REQUEST", "GetMap" );
>> $req->setParameter( "BBOX", "-180,-90,180,90" );
>> $req->setParameter( "LAYERS", "layer_name");
>> $req->setParameter( "SRS", "-1");
>> $req->setParameter( "WIDTH", "1200");
>> $req->setParameter( "HEIGHT", "600");
>> my $dispatch_out = $map->OWSDispatch( $req );
>> my $map_img = 'test_' . sprintf("%0.10d", rand(1000000000)) . '.png';
>> $img->save("/path/to/$map_img");
>> return send_file("/path/to/$map_img");
>> Comments? Corrections?
> Puneet,
> I rarely use PHP and it is possible something is broken now with PHP
> OWS dispatching. But it should work like:
> http://mapserver.org/ogc/mapscript.html#php-example
> Alternatively if you don't install the stdout redirection the OWSDispatch
> call should produce the image to stdout.
> Note that if you want things handled properly as a WMS request you should
> not be calling draw(). The ticket you reference long predates the WxS
> MapScript services effort.
> I suspect you are not really setting all the environment variables needed
> to make the WMS handler kick in during OWSDispatch though I'd have to
> play around with it to be sure.
Frank,
The above code was for (ahem) Perl MapScript. I am sure you are correct that I am not setting all the environment variables. I am hoping for a tutorial or code fragment that shows how to do it correctly. The one in the documentation that I am following doesn't seem to have any more than what I am setting. The following is the entirety of my non-working code (simplified bit for brevity, and also available with syntax highlighting at [http://pastebin.com/fz6MCXpm]) --
use DBI;
use mapscript;
my $map = new mapscript::mapObj() or warn "error: $mapscript::ms_error->{message}\n";
$map->{name} = 'mymap';
$map->{status} = $mapscript::MS_ON;
$map->{units} = $mapscript::MS_DD;
$map->setImageType('png');
my $imageColor = new mapscript::colorObj;
$imageColor->setHex('#FFFFFF');
$map->{imagecolor} = $imageColor;
$map->setSize(1200, 600);
$map->setExtent(-180, -90, 180, 90);
$map->selectOutputFormat('png');
$map->setProjection("proj=latlong");
my $outputFormatObj = new mapscript::outputFormatObj('AGG/PNG');
$outputFormatObj->setExtension('png');
$outputFormatObj->setMimetype('image/png');
$outputFormatObj->{imagemode} = $mapscript::MS_IMAGEMODE_RGB;
$map->setOutputFormat( $outputFormatObj );
my $layerOne = new mapscript::layerObj($map);
$layerOne->{name} = "layer one";
$layerOne->{status} = $mapscript::MS_ON;
$layerOne->{type} = $mapscript::MS_LAYER_POLYGON;
$layerOne->{opacity} = 100;
$layerOne->{connection} = 'host=localhost port=5432 dbname=mydb user=dbuser password=dbpasswd';
$layerOne->setConnectionType($mapscript::MS_POSTGIS, '');
$layerOne->{data} = 'the_geom FROM (SELECT class_name, the_geom FROM t1) a_view USING UNIQUE gid USING srid=-1';
$layerOne->{classitem} = 'class_name';
$layerOne->setProjection("proj=latlong");
my $classOutlineColor = new mapscript::colorObj;
$classOutlineColor->setHex('#444444');
my $sth = database->prepare('SELECT class_name, class_color FROM t2');
$sth->execute;
while (my ($class_name, $class_color) = $sth->fetchrow_array) {
my $classObj = new mapscript::classObj($layerOne);
$classObj->{name} = $class_name;
$classObj->setExpression("$class_name");
my $classFillColor = new mapscript::colorObj;
$classFillColor->setHex($class_color);
my $styleObj = new mapscript::styleObj($classObj);
$styleObj->{color} = $classFillColor;
$styleObj->{outlinecolor} = $classOutlineColor;
$sth->finish;
$req->setParameter( "BBOX", "-173.537,35.8775,-11.9603,83.8009" );
$req->setParameter( "LAYERS", "layer one");
my $io = mapscript::msIO_installStdoutToBuffer();
printf "%s\n", mapscript::msIO_getStdoutBufferString();
Anything stand out that I am doing wrong above? Or, stuff that I am missing?
Many thanks in advance,
Puneet.
