[mapserver-users] Re: Getting blank tiles in google maps
forums
forums at craniumjuice.com
Thu Sep 8 14:07:54 EDT 2011
Have you verified that the map will display when not in tile mode?
http://localhost:8088/cgi-bin/mapserv.exe?map=C:/ms4w/apps/gmap/htdocs/hampshire.map&layers=HampshireAreas&mode=map<http://localhost:8088/cgi-bin/mapserv.exe?map=C:/ms4w/apps/gmap/htdocs/hampshire.map&layers=HampshireAreas&mode=tile&tilemode=gmap&tile=[x]+[y]+[z]>
On Thu, Sep 8, 2011 at 12:47 PM, vaibhavgarg <vaibhavkumargarg at gmail.com>wrote:
> (retrying message)
> Hi all, I am new to MapServer.
> I have downloaded and setup MS4W and was able to overlay the example Bath
> and other map data on google maps.
> I then created my own .map file using QGIS and supplied my data but the
> served tiles are completely blank(transparant or white when I select RGB).
> My data set is .GML and I also tried converting it to .SHP format. I have
> checked that my setup is ok by doing is on two different computers.
> When I use shp2img.exe then it renders the layers properly.
> c:\> shp2img.exe -m hampshire.map -o hampshire.png -s 2048 2048
> I am using this URL scheme:
> I have attached all the relevant files. (2 sets, one is .SHP and the other
> is .GML, both cases I get transparent empty tiles)
> Can anyone please help me identify the reason why the generated tiles are
> transparent and how I can fix it.
> (7MB total, 1MB pieces, sorry if this is large, I am new to mailing lists
> too, please use 7Z to unzip)
> SHP: Hampshire.map Hampshire.7z.001...006
> GML: Hampshire-gml.map Hampshire-gml.7z
> Download links here: (7z, 7mb total)
> http://osgeo-org.1803224.n2.nabble.com/Getting-blank-tiles-in-google-maps-td6746323.html
> Alternate download (zip format, 14mb)
> http://www.megaupload.com/?d=DAD6SR5P
> Thanks you very much.
> Vaibhav G
> http://osgeo-org.1803224.n2.nabble.com/Getting-blank-tiles-in-google-maps-tp6772814p6772946.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
A computer without Windows is like chocolate cake without mustard.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110908/1e1c18c1/attachment.html
