[mapserver-users] how to specify the location of projection
library, how to do it not in map file?
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Sep 8 17:02:27 EDT 2011
On 9/8/2011 5:05 PM, JK Chen wrote:
> Hi,
> I specify the location proj library in the map file, which points to apache cgin-bin dirs.. Because we have 32 bit and 64 bit machines, and the paths of the apache software on those two types machines are not the same, I end up having two map files.
> That creates installation problems for us. I'm wondering if there is more elegant way to specify the path to proj library?
> In basegn.x32.map
> CONFIG "PROJ_LIB" "C:/Program Files/Apache Software Foundation/Apache2.2/cgi-bin/"
> In basegn.x64.map
> CONFIG "PROJ_LIB" "C:/Program Files (x86)/Apache Software Foundation/Apache2.2/cgi-bin/"
I believe you can set this up as an environment variable in each apache
instance so so it points to the correct file. You would have to do this
in the apache config file(s).
-Steve W
