[mapserver-users] MapScript WMS request
Daniel Morissette
dmorissette at mapgears.com
Thu Sep 8 18:28:16 PDT 2011
On 11-09-08 09:02 PM, Mr. Puneet Kishor wrote:
> On Sep 8, 2011, at 7:43 PM, Daniel Morissette wrote:
>> Maybe call $map->save("/tmp/my.map") in your script after the map and layer have been populated and paste the result... that may give us a hint...
> wow! this is a super-awesome debugging technique. I have sent you the map file off list to not pollute the entire list serve.
I was able to reproduce the issue with the copy of the mapfile you sent
off-list.
It turns out that mappostgis.c's msPostGISLayerGetExtent() is hardcoded
to always return
{minx = -25000000, miny = -25000000, maxx = 25000000, maxy = 25000000}
...and then it returns MS_SUCCESS.
I think this function should either be left unimplemented (this way
MapServer would fallback on other mechanisms), or return MS_FAILURE to
indicate to the calling code that it didn't do anything useful.
A quick search indicates an open ticket about the issue:
http://trac.osgeo.org/mapserver/ticket/3585
You could bump the ticket and hope someone works on it at the FOSS4G
code sprint next week.
The short term fix for you would be to set the "ows_extent" metadata in
your layer:
METADATA
"ows_extent" "-180 -90 180 90"
END
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
More information about the MapServer-users
