[mapserver-users] querying in mode=tile
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Sep 12 00:41:34 EDT 2011
If you happen to have a little bit time for considering some day, consider also using WFS for queries. And if you cannot manage to get the geojson outputformat work through the OGR outputformat system in a minute, you can install TinyOWS besides Mapserver. It can read the same mapfiles and it can output geojson out-of-the-box.
-Jukka Rahkonen-
Mr. Puneet Kishor wrote:
>On Sep 11, 2011, at 10:52 PM, Richard Greenwood wrote:
>> On Sun, Sep 11, 2011 at 9:37 PM, Mr. Puneet Kishor <punk.kish at gmail.com> wrote:
>>> However, since I am not using MapScript (even though I would prefer to), I would have to implement both CGI and MapScript to do what you are suggesting above -- CGI to display the map and MapScript to do the query.
>> But my point was that you can do the query without mapserver at all if
> the data is in postgis. Use a server-side language such as Perl or PHP
> to pass the request to postgis, which can do a spatial query, and then
> Perl or PHP can format the result as JSON and return it to the page
> (via AJAX).
> On second reading, I now get what you are saying. Strange that it never occurred to me. Sounds very sensible, and I will implement it tomorrow. That way I can get away from CGI `mode=query` and its TEMPLATE-ing vagaries. Yes, my data are in Pg, so I can do all my querying with Perl.
> Wish I could do away with `mode=tile` and also get tiles back via MapScript. Then my solution would be complete.
>Thanks for this really useful hint (more like making me see the obvious that I was missing for some reason).
Puneet._______________________________________________
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
