[mapserver-users] SLD with LayerFeatureConstraints
Kralidis,Tom [Ontario]
Tom.Kralidis at ec.gc.ca
Tue Sep 13 07:36:31 EDT 2011
At thispoint, filtering is only supported via UserStyle. Having said
this, please submit a trac ticket for the requirement. Not sure when/if
it would be addressed.
..Tom
> -----Original Message-----
> From: Meine Toonen [mailto:meinetoonen at b3partners.nl]
> Sent: Tuesday, 13 September 2011 05:56
> To: Kralidis,Tom [Ontario]; mapserver-users at lists.osgeo.org
> Subject: RE: [mapserver-users] SLD with LayerFeatureConstraints
> Thanks for the info.
> Will the LayerFeatureConstraints options be available in the future,
or is
> filtering only supported in an UserStyle? Couldn't find it in the
trac.
> Met vriendelijke groet,
> Meine Toonen
> B3Partners BV
> Tel: 030 214 2083
> ________________________________
> From: Kralidis,Tom [Ontario] [mailto:Tom.Kralidis at ec.gc.ca]
> To: Meine Toonen [mailto:meinetoonen at b3partners.nl], mapserver-
> Sent: Mon, 12 Sep 2011 16:56:33 +0200
> > From: mapserver-users-bounces at lists.osgeo.org
[mailto:mapserver-
> users-
> > bounces at lists.osgeo.org] On Behalf Of Meine Toonen
> > Sent: Monday, 12 September 2011 10:22
> > To: mapserver-users at lists.osgeo.org
> > Subject: [mapserver-users] SLD with LayerFeatureConstraints
> > Hi list,
> > I'm currently trying to filter features from a layer via a
SLD, but
> using
> > the style defined by the service. I managed to get a
NamedStyle by
> defining
> > a classgroup and assigning the class with the group.
> > When I set the style via SLD to mv2, it works perfectly, but
when I
> add the
> > filterpart (LayerFeatureConstraints) it fails: the default
style is
> used
> > and no filtering occurs.
> > Am I doing something wrong, of is filtering nog possible via
> > LayerFeatureConstraints?
> > Mapfile:
> > layer
> > name telpunten_motorvoertuig_punt
> > CLASSGROUP "mv"
> > metadata
> > "wms_title" "telpunten_points"
> > "gml_include_items" "all"
> > "wfs_featureid" "id"
> > end
> > group telpunten
> > status off
> > type point
> > dump true
> > template bla
> > connectiontype postgis
> > connection CONNECTIONSTATEMENT
> > data "locatie from (select id, nummer, locatie,
> > coalesce(soort,'Onbekend') as wb_soort, wegnummer from telpunt
) as
> foo
> > using srid=28992 using unique id"
> > projection
> > "init=epsg:28992"
> > end
> > classitem wb_soort
> > class
> > NAME "motorvoertuig"
> > group "mv"
> > expression "MOTORVOERTUIG"
> > style
> > symbol "square"
> > color 0 204 204
> > outlinecolor 0 0 0
> > size 8
> > end
> > end
> > class
> > NAME "motorvoertuig2"
> > group "mv2"
> > style
> > symbol "square"
> > color 255 0 0
> > outlinecolor 0 0 0
> > size 8
> > end
> > end
> > processing "CLOSE_CONNECTION=DEFER"
> > end
> > The SLD:
> > <?xml version="1.0" encoding="UTF-8"?>
> > <sld:StyledLayerDescriptor
xmlns:app="http://www.deegree.org/app"
> <http://www.deegree.org/app%22>
> > xmlns:deegreeogc="http://www.deegree.org/ogc"
> <http://www.deegree.org/ogc%22>
> > xmlns:gml="http://www.opengis.net/gml"
> <http://www.opengis.net/gml%22>
> > xmlns:ogc="http://www.opengis.net/ogc"
> <http://www.opengis.net/ogc%22>
> > xmlns:sld="http://www.opengis.net/sld"
> <http://www.opengis.net/sld%22>
> > xmlns:xlink="http://www.w3.org/1999/xlink"
> <http://www.w3.org/1999/xlink%22>
> > xmlns:se="http://www.opengis.net/se"
<http://www.opengis.net/se%22>
> version="1.0.0">
> > <sld:NamedLayer xmlns="http://www.opengis.net/sld"
> <http://www.opengis.net/sld%22> >
> > <se:Name>telpunten_motorvoertuig_punt</se:Name>
> > <sld:NamedStyle>
> > <se:Name>mv</se:Name>
> > </sld:NamedStyle>
> > <sld:LayerFeatureConstraints>
> > <Fsld:eatureTypeConstraint>
> > <ogc:Filter>
> > <ogc:PropertyIsEqualTo>
> > <ogc:PropertyName>wegnummer</ogc:PropertyName>
> > <ogc:Literal>A28</ogc:Literal>
> > </ogc:PropertyIsEqualTo>
> > </ogc:Filter>
> > </sld:FeatureTypeConstraint>
> > </sld:LayerFeatureConstraints>
> > </sld:NamedLayer>
> > </sld:StyledLayerDescriptor>
> > Thanks in advance!
> Sld:LayerFeatureConstraints is not supported by MapServer, or
SLD
> 1.0.0.
> FYI here's an example of applying filters to SLD:
> <StyledLayerDescriptor version="1.0.0"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> <http://www.w3.org/2001/XMLSchema-instance%22>
> xsi:schemaLocation="http://www.opengis.net/sld
> http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd"
> <http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd%22> >
> <Name>ms_ogc_workshop</Name>
> <Title>SLD for MapServer OGC Web Services Workshop</Title>
> <Abstract>This is an SLD to show how one can make a custom style
> without having to change the data style at the
server-side</Abstract>
> <NamedLayer>
> <Name>rivers</Name>
> <UserStyle>
> <Name>sld_01</Name>
> <Title>sld_01</Title>
> <IsDefault>1</IsDefault>
> <FeatureTypeStyle>
> <Rule>
> <ogc:Filter>
> <ogc:PropertyName>NAME</ogc:PropertyName>
> <ogc:Literal>Japura</ogc:Literal>
> </ogc:Filter>
> <LineSymbolizer>
> <Stroke>
> <CssParameter
> name="stroke">#FFCC00</CssParameter>
> <CssParameter
> name="stroke-width">5</CssParameter>
> </Stroke>
> </LineSymbolizer>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
> </StyledLayerDescriptor>
