[mapserver-users] Generic template for WMS GetFeatureInfo
Steve Lime
sdlime at gmail.com
Thu Sep 15 14:43:06 EDT 2011
Hi Julian: You might try the [items] and [values] template tags combined with a little JavaScript. Those tags output a delimited list of items and values for a feature or set of features. You could split the output into arrays and display however you like. The attributes are just slammed together into 1 comma delimited string, so this approach won't work if your attribute data contains commas I fear. The same template in theory could be used for any layer then... You could use new-style templates (e.g. Via output formats) with template includes and handle this with 2 files- the main template and the shared include...
I notice those tags aren't documented so I'll create a ticket to do so. Should also probably enhance those tags, at least the values one, to take some simple formatting options.
Steve
Sent from my iPad
On Sep 14, 2011, at 8:39 AM, "Hollingbery, Julian" <julho at kms.dk> wrote:
> Hi list,
> I too want to serve GetFeatureInfo requests. However, I wonder if it is necessary to have a template per layer, when all I want to do is "show all attribute values in a HTML table". The thing is, I have a handful of services with approx. 40 layers in each. Each layer has on average a dozen attributes, so all in all, I am looking to simplify maintenance of 2000 HTML table cells. Has anyone done anything in a script or otherwise, so that one can use the same template file on layers with varying attribute lists?
> I am considering utilising the fact that a TEMPLATE statement can reference a URL: I imagine that this might refer to a PHP-script, which takes e.g. a database table name, and returns a HTML response with the column names. Has anyone done anything like this?
> Regards,
> Julian Hollingbery
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110915/013ac6e0/attachment.html
