[mapserver-users] Runtime Substitution bug
Steve Lime
sdlime at gmail.com
Thu Sep 15 14:46:40 EDT 2011
If you take var. substitution out of it by hard coding an idblock value does the space still matter?
Steve
Sent from my iPad
On Sep 15, 2011, at 11:07 AM, "Nicolas BOUTET" <nicolas.boutet at geosys.com> wrote:
> Hello,
> I’m using MapServer 6.0.1 in conjunction with GDAL 1.8 (Tamas binaries) with IIS 7.5, and I get an issue while using runtime substitution.
> I have a LAYER where the data source if defined like this :
> CONNECTIONTYPE OGR
> CONNECTION "OCI:…/…. at gti5500"
> DATA "SELECT idblock, entitiesMbr
> FROM block
> WHERE idblock = %idBlock% "
> Please note that there is a space character at the end of the SQL statement, after the variable to substitute.
> All is working fine while the space is still here.
> If I remove it, I get an Error 500 from the Server and the Windows Application logs register an error in the MSVCR100.dll module.
> Of course, the layer contains also a validation block like this:
> VALIDATION
> idblock '^[0-9]{1,6}$'
> END
> It seems that this is a bug in variable substitution. Can you confirm this? Have you already observe this kind of issue?
> Regards
> Nicolas
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110915/a70b9ef0/attachment-0001.html
