[mapserver-users] Runtime Substitution bug
    Steve.Toutant at inspq.qc.ca
    Fri Sep 16 05:25:17 PDT 2011
Have a look at this ticket
http://trac.osgeo.org/mapserver/ticket/3999
Perhaps it is a similar issue. Maybe try to change your variable name
idblock
"Nicolas BOUTET" <nicolas.boutet at geosys.com>@lists.osgeo.org
Envoyé par : mapserver-users-bounces at lists.osgeo.org
2011-09-16 03:37
A
"'Steve Lime'" <sdlime at gmail.com>
cc
mapserver-users at lists.osgeo.org
Objet
RE: [mapserver-users] Runtime Substitution bug
Hi Steve,
If I remove the substitution variable and replace it by a value, it
doesn?t matter if there is a space or not.
I also tried with some others SQL statements where the substitution
variable is not at the end of the SQL String. There is no problem with
those SQL Statements.
Nicolas
De : Steve Lime [mailto:sdlime at gmail.com]
Envoyé : jeudi 15 septembre 2011 20:47
À : Nicolas BOUTET
Cc : <mapserver-users at lists.osgeo.org>; <mapserver-dev at lists.osgeo.org>
Objet : Re: [mapserver-users] Runtime Substitution bug
If you take var. substitution out of it by hard coding an idblock value
does the space still matter?
Steve
Sent from my iPad
On Sep 15, 2011, at 11:07 AM, "Nicolas BOUTET" <nicolas.boutet at geosys.com>
wrote:
Hello,
I?m using MapServer 6.0.1 in conjunction with GDAL 1.8 (Tamas binaries)
with IIS 7.5, and I get an issue while using runtime substitution.
I have a LAYER where the data source if defined like this :
                               CONNECTIONTYPE         OGR
                               CONNECTION "OCI:?/?. at gti5500"
                               DATA "SELECT idblock, entitiesMbr
                                               FROM block
                                               WHERE idblock = %idBlock% "
Please note that there is a space character at the end of the SQL
statement, after the variable to substitute.
All is working fine while the space is still here.
If I remove it, I get an Error 500 from the Server and the Windows
Application logs register an error in the MSVCR100.dll module.
Of course, the layer contains also a validation block like this:
                                VALIDATION
                                               idblock '^[0-9]{1,6}$'
                               END
It seems that this is a bug in variable substitution. Can you confirm
this? Have you already observe this kind of issue?
Regards
Nicolas
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110916/d1e9076a/attachment.htm>
More information about the MapServer-users
