[mapserver-users] recommended tile caching mechanism with `mode=tile`
thomas bonfort thomas.bonfort at gmail.com
Sun Sep 18 11:49:22 PDT 2011
To be a bit more precise, everything *except* blank tile linking
should work on windows, but that code is already ifdef'd out for win32
and so should not pose any build problem.
thomas
On Sun, Sep 18, 2011 at 12:41, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> There are no known limitations in running on windows, as it is based
> largely on the cross-platform apr library. That said, I have
> absolutely no idea on how to build stuff on windows, and so the build
> files will have to be contributed before things can start moving on
> that platform.
> regards,
> thomas
> On Sun, Sep 18, 2011 at 10:52, John Callahan <john.callahan at udel.edu> wrote:
>> I'm sure lots of people are very interested in this topic.  Very nice.   I'm
>> assuming at some point MapServer MapCache will be supported on the Windows
>> platform.  (IIRC, I do not believe mod-geocache is supported there.)   Is
>> that true and can the current trunk be built on Windows?
>> - John
>> On Sun, Sep 18, 2011 at 11:02 AM, thomas bonfort <thomas.bonfort at gmail.com>
>> wrote:
>>> On Sun, Sep 18, 2011 at 08:08, Mr. Puneet Kishor <punk.kish at gmail.com>
>>> wrote:
>>> > On Sep 17, 2011, at 11:43 PM, Daniel Morissette wrote:
>>> >> On 11-09-18 12:08 AM, Mr. Puneet Kishor wrote:
>>> >>> I am using MapServer cgi with `mode=tile` with a Google Maps
>>> >>> front-end, and am wondering what is a recommended tile cache server.
>>> >>> Any suggestions from personal experience?
>>> >> MapServer MapCache of course! It is a fully featured, robust and fast
>>> >> tiling server. Only available in MapServer SVN trunk at the moment.
>>> >> http://mapserver.org/trunk/mapcache/
>>> >> It was formerly known as Mod-Geocache until a few weeks ago... the
>>> >> website is in the process of being migrated to the above URL, but in the
>>> >> meantime you can still reach the old site:
>>> >> http://code.google.com/p/mod-geocache/
>>> > Very nice. I look forward to installing this; hopefully, it will be
>>> > straightforward.
>>> > A couple of questions --
>>> > 1. I was looking at mod_cache (mod_disk_cache and mod_mem_cache)
>>> > yesterday and wondering if they could be used to cache the images. Is
>>> > mod_geocache inspired/based on those modules?
>>> As already stated by Mike, there's quite a bit of geo related
>>> intermediary glue code that translates the incoming request into the
>>> actual name of the tile as stored on the system, which makes the
>>> module much more specific than the mod_*_cache existing modules.
>>> There is a memcached storage backend for mapcache, but speed of access
>>> to the tile data is not a use-case that it shines at: it is slower
>>> than disk based caches, but allows the automatic expiring of tiles
>>> based on their creation date.
>>> > 2. Why wed this to Apache? By making it web-server agnostic, you open up
>>> > the audience.
>>> c.f. the fastcgi implementation. cgi is not a recommended setup.
>>> thomas
>>> > Puneet.
>>> > _______________________________________________
>>> > mapserver-users mailing list
>>> > mapserver-users at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
