[mapserver-users] Display raster image
Matt McClelland
matt at wildwalks.com
Mon Sep 19 23:59:44 EDT 2011
Thanks Jukka
The projection block did the trick.
Now producing beautiful maps :)
Thanks
Matt :)
On Tue, Sep 20, 2011 at 1:48 PM, Rahkonen Jukka
<Jukka.Rahkonen at mmmtike.fi>wrote:
> Hi,
> Usually this means that everything is OK but you are somehow asking image
> from an area that is not covered by your image. Tell us
> - the EXTENT in your mapfile
> - the PROJECTION block of the mapfile at MAP level
> - the request you are using for getting the image
> Add DEBUG 5 into your mapfile and you will get useful information into log
> file that is defined with MS_ERRORFILE
> It is good to use projection block for all the layers too. In your case it
> looks like is should be
> PROJECTION
> "init=epsg:4326"
> END
> -Jukka Rahkonen-
> Matt McClelland wrote:
> > Hi
> > I am wanting to display a geotiff for map shading, but it is not
> displaying
> > I have this as the first layer entry in the .map file
> > LAYER
> NAME "hillshade"
> DATA "/var/www/osm/hill/S34E151.tif"
> TYPE RASTER
> STATUS ON
> END
> > and even when I generate a map with just the hillshade layer (in the area
> of the tif) there is no hill shading
> > If I change the file name to something silly, I get an error saying the
> file can not be found, but as is there is no > error message. With just the
> hillshade layer on I just get a white image back.
> > Any hints on how I might solve this???
> Running # gdalinfo S34E151.tif
> give me this
> Driver: GTiff/GeoTIFF
> Files: S34E151.tif
> Size is 1201, 1201
> Coordinate System is:
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4326"]]
> Origin = (150.999583333333334,-32.999583333333334)
> Pixel Size = (0.000833333333333,-0.000833333333333)
> Metadata:
> AREA_OR_POINT=Area
> Image Structure Metadata:
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left ( 150.9995833, -32.9995833) (150d59'58.50"E, 32d59'58.50"S)
> Lower Left ( 150.9995833, -34.0004167) (150d59'58.50"E, 34d 0' 1.50"S)
> Upper Right ( 152.0004167, -32.9995833) (152d 0' 1.50"E, 32d59'58.50"S)
> Lower Right ( 152.0004167, -34.0004167) (152d 0' 1.50"E, 34d 0' 1.50"S)
> Center ( 151.5000000, -33.5000000) (151d30' 0.00"E, 33d30' 0.00"S)
> Band 1 Block=1201x6 Type=Byte, ColorInterp=Gray
> NoData Value=0
> Matt :)
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110920/9ce0cb73/attachment.html
