[mapserver-users] Text outline not working on line features
thomas bonfort
thomas.bonfort at gmail.com
Wed Sep 21 21:17:40 EDT 2011
The GD driver does not support the OUTLINEWIDTH keyword on labels, but
you should see a hard 1-pixel outline be applied to the text.
thomas
On Tue, Sep 20, 2011 at 22:56, Bistrais, Bob <Bob.Bistrais at maine.gov> wrote:
> This is an older version of MapServer, MS4W 2.3.1, MapServer 5.2.1.
> Using a global file with the outputformat params:
> OUTPUTFORMAT
> NAME 'agg/png'
> DRIVER AGG/PNG
> IMAGEMODE RGBA
> FORMATOPTION "TRANSPARENT=TRUE"
> END
> OUTPUTFORMAT
> NAME 'print'
> DRIVER "GD/GIF"
> MIMETYPE "image/gif"
> IMAGEMODE PC256
> EXTENSION "gif"
> TRANSPARENT ON
> END
> -So we're going to gif on the printout.
> Not sure what you meant by label output. But here's what I see- on the
> web application, the labels are as they should be- they have the
> background halo. On the printed map, the label text itself appears, but
> no background halo.
> Yes, I'm absolutely sure that's the code being used in the .map file.
> -----Original Message-----
> From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
> Sent: Tuesday, September 20, 2011 1:49 PM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Text outline not working on line features
> Bob,
> Also, what are you getting for label output in you case? More info would
> help diagnose this.
> Thanks,
> -Steve W
> On 9/20/2011 1:47 PM, thomas bonfort wrote:
>> what mapserver version, what outputformat?
>> regardless, it should work with any version, are you sure that this is
>> the actual mapfile snippet that is being used ?
>> thomas
>> On Tue, Sep 20, 2011 at 18:45, Bistrais, Bob<Bob.Bistrais at maine.gov>
> wrote:
>>> I'm trying to draw and label road features from a shapefile. I'd
> like to
>>> include an outline of the road name text as a halo. This works fine
> on
>>> polygon and point features, but is not working for me with the line
>>> features.
>>> Here is the code block:
>>> LABEL
>>> ANGLE auto
>>> PARTIALS false
>>> FORCE false
>>> MINDISTANCE 250
>>> POSITION uc
>>> COLOR 200 0 0
>>> OUTLINECOLOR 255 255 255
>>> OUTLINEWIDTH 5
>>> FONT "verdana"
>>> SIZE 12
>>> TYPE truetype
>>> END
>>> TEXT ([RDNAME])
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
