[mapserver-users] Re: WMS layers get canceled
Puneet Kishor
punk.kish at gmail.com
Thu Sep 22 23:47:22 EDT 2011
a bit more on this below --
On Sep 22, 2011, at 9:17 PM, Puneet Kishor wrote:
> I am unable to figure this out --
> My app front is Google Maps API v3 with MapServer 6.0.1
> $./mapserv -v
> MapServer version 6.0.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=GEOS INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE
> The app fires WMS requests that look like so in Firebug and Safari Web Inspector (one per tile)
> http://path/to/server/cgi-bin/app?version=1.1.1&request=GetMap&format=image/png&TRANSPARENT=TRUE&Styles=&SRS=EPSG:4326&Layers=lyr&width=256&height=256&BBOX=-135,40.97989806962013,-90,66.51326044311185
> The status code in Firebug is "Aborted" ("Canceled" in Safari Web Inspector). The ms_error file kicks in the following messages --
> [Thu Sep 22 21:00:55 2011].347078 msWMSLoadGetMapParams(): enabling non-square pixels.
> [Thu Sep 22 21:00:55 2011].347608 msDrawMap(): kicking into non-square pixel preserving mode.
> [Thu Sep 22 21:00:55 2011].347615 msDrawMap(): rendering using outputformat named png24 (AGG/PNG).
> My .map file has the following incantation --
> #### in the MAP section #####
> PROJECTION
> "init=epsg:4326"
> END
> WEB
> METADATA
> ows_enable_request "*"
> wms_abstract "blah blah"
> wms_accessconstraints "none"
> wms_title "gpsvecs"
> wms_onlineresource "http://path/to/server/cgi-bin/gpsvecs?"
> wms_srs "EPSG:4326"
> wms_keywordlist "foo,bar"
> wms_enable_request "*"
> END
> END
> #### in the LAYER section ####
> LAYER
> NAME "lyr"
> CONNECTION "host=localhost port=5432 dbname=db user=user password=passwd"
> CONNECTIONTYPE POSTGIS
> PROCESSING "CLOSE_CONNECTION=DEFER"
> DATA "the_geom FROM (SELECT gid, a, b, the_geom FROM table) foo USING UNIQUE gid USING srid=4326"
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> wms_srs "EPSG:4326"
> wms_title "lyr"
> wms_extent "-180 -90 180 90"
> END
> Suggestions?
Seems like when fired by Google Maps, MapServer doesn't return any Response Headers. If I take the same query and send it manually, I get the response headers, and I get a nice image back. Any idea what is going on? My guess is I am doing something wrong on the Gmaps side. Here is my relevant code
var lyr = new google.maps.ImageMapType({
"getTileUrl" : function (tile, zoom) {
return uri + "layers=" + name + "&mode=tile&tilemode=gmap&tile=" + tile.x + "+" + tile.y + "+" + zoom;
"tileSize" : new google.maps.Size(256, 256),
"isPng" : false,
"opacity" : 0.5,
"maxZoom" : 22,
"minZoom" : 1,
"alt" : "",
"name" : name
map.overlayMapTypes.push(lyr)
