[mapserver-users] Re: problem with mercator projection
fred p
mapoubelle22 at gmail.com
Fri Sep 23 04:10:17 EDT 2011
Hello
Nobody has got an idea whether I am wrong somewhere or there is a problem in
the image or ... ?
I add the result is OK in EPSG:4326 whatever the bbox is and it is OK too in
EPSG:3395 provided the extent longitude is smaller than 360°. However when
it is higher...
Thanks in advance
2011/9/21 fred p <mapoubelle22 at gmail.com>
> Hello !
> I am trying to serve an image in Mercator projection (EPSG:3395) with an
> extent larger than "360° in longitude" but I get a truncated and reversed in
> longitude image.
> Do I make a mistake somewhere?
> Thanks for your help
> The mapfile content and the gdalinfo output on the original image are given
> below.
> Mapserver version: 6.0.1
> Call to mapserver:
> /path/to/mapserv -nh "QUERY_STRING=map=/tmp/world.
> map&service=wms&LAYERS=countries&FORMAT=image/png&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&STYLES=&SRS=epsg:3395&BBOX=-26080550.098232,-15000000,26080550.098232,15000000&WIDTH=885&HEIGHT=509"
> Content of the mapfile:
> MAP
> EXTENT -180 -90 180 90
> IMAGECOLOR 255 255 255
> IMAGETYPE agg
> STATUS ON
> OUTPUTFORMAT
> NAME "agg"
> MIMETYPE "image/png"
> DRIVER "AGG/PNG"
> EXTENSION "png"
> IMAGEMODE "RGBA"
> TRANSPARENT TRUE
> FORMATOPTION "INTERLACE=false"
> END
> PROJECTION
> "init=epsg:4326"
> END
> WEB
> METADATA
> "wms_srs" "epsg:4326 epsg:3395 epsg:900913 epsg:3995"
> "OWS_ENABLE_REQUEST" "*"
> END
> END
> LAYER
> DATA "/tmp/world.tif"
> NAME "countries"
> PROJECTION
> "init=epsg:4326"
> END
> STATUS ON
> TYPE RASTER
> END
> END
> Output of gdalinfo command:
> $ gdalinfo /tmp/world.tif
> Driver: GTiff/GeoTIFF
> Files: /tmp/world.tif
> Size is 1000, 500
> Coordinate System is:
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4326"]]
> Origin = (-180.000000000000000,90.000000000000000)
> Pixel Size = (0.360000000000000,-0.360000000000000)
> Metadata:
> TIFFTAG_DOCUMENTNAME=/tmp/world.tif
> TIFFTAG_XRESOLUTION=72
> TIFFTAG_YRESOLUTION=72
> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> AREA_OR_POINT=Area
> Image Structure Metadata:
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left (-180.0000000, 90.0000000) (180d 0'0.00"W, 90d 0'0.00"N)
> Lower Left (-180.0000000, -90.0000000) (180d 0'0.00"W, 90d 0'0.00"S)
> Upper Right ( 180.0000000, 90.0000000) (180d 0'0.00"E, 90d 0'0.00"N)
> Lower Right ( 180.0000000, -90.0000000) (180d 0'0.00"E, 90d 0'0.00"S)
> Center ( 0.0000000, 0.0000000) ( 0d 0'0.01"E, 0d 0'0.01"N)
> Band 1 Block=1000x8 Type=Byte, ColorInterp=Gray
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110923/0cc6aa30/attachment.html
