[mapserver-users] Re: problem with mercator projection
fred p
mapoubelle22 at gmail.com
Mon Sep 26 07:22:29 EDT 2011
Thanks to Jukka for this first input.
The given example is similar to what I want to get.
Rendering the image in separate tiles could be an alternative but for some
reasons I would prefer get the whole image within a single call to the
server.
Anybody has got an idea ?
Fred
2011/9/23 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> Hi,
> You perhaps want to achieve a map presenting the whole world once and then
> some extra from the second round in the margins like
> http://www.openstreetmap.org/?lat=59&lon=-39&zoom=1&layers=M? It might
> well be that the transformation functions consider that for EPSG:3395 the
> maximum values really are the bounds reported at
> http://spatialreference.org/ref/epsg/3395/ and values outside the value
> range are invalid. I have no idea about how you could get your map out from
> WMS. Could you consider composing it from pieces somehow?
> -Jukka Rahkonen-
> *Lähettäjä:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *Puolesta *fred p
> *Lähetetty:* 23. syyskuuta 2011 11:10
> *Vastaanottaja:* mapserver-users at lists.osgeo.org
> *Aihe:* [mapserver-users] Re: problem with mercator projection
> Hello
> Nobody has got an idea whether I am wrong somewhere or there is a problem
> in the image or ... ?
> I add the result is OK in EPSG:4326 whatever the bbox is and it is OK too
> in EPSG:3395 provided the extent longitude is smaller than 360°. However
> when it is higher...
> Thanks in advance
> 2011/9/21 fred p <mapoubelle22 at gmail.com>
>> Hello !
>> I am trying to serve an image in Mercator projection (EPSG:3395) with an
>> extent larger than "360° in longitude" but I get a truncated and reversed in
>> longitude image.
>> Do I make a mistake somewhere?
>> Thanks for your help
>> The mapfile content and the gdalinfo output on the original image are
>> given below.
>> Mapserver version: 6.0.1
>> Call to mapserver:
>> /path/to/mapserv -nh "QUERY_STRING=map=/tmp/world.
>> map&service=wms&LAYERS=countries&FORMAT=image/png&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&STYLES=&SRS=epsg:3395&BBOX=-26080550.098232,-15000000,26080550.098232,15000000&WIDTH=885&HEIGHT=509"
>> Content of the mapfile:
>> MAP
>> EXTENT -180 -90 180 90
>> IMAGECOLOR 255 255 255
>> IMAGETYPE agg
>> STATUS ON
>> OUTPUTFORMAT
>> NAME "agg"
>> MIMETYPE "image/png"
>> DRIVER "AGG/PNG"
>> EXTENSION "png"
>> IMAGEMODE "RGBA"
>> TRANSPARENT TRUE
>> FORMATOPTION "INTERLACE=false"
>> END
>> PROJECTION
>> "init=epsg:4326"
>> END
>> WEB
>> METADATA
>> "wms_srs" "epsg:4326 epsg:3395 epsg:900913 epsg:3995"
>> "OWS_ENABLE_REQUEST" "*"
>> END
>> END
>> LAYER
>> DATA "/tmp/world.tif"
>> NAME "countries"
>> PROJECTION
>> "init=epsg:4326"
>> END
>> STATUS ON
>> TYPE RASTER
>> END
>> END
>> Output of gdalinfo command:
>> $ gdalinfo /tmp/world.tif
>> Driver: GTiff/GeoTIFF
>> Files: /tmp/world.tif
>> Size is 1000, 500
>> Coordinate System is:
>> GEOGCS["WGS 84",
>> DATUM["WGS_1984",
>> SPHEROID["WGS 84",6378137,298.257223563,
>> AUTHORITY["EPSG","7030"]],
>> AUTHORITY["EPSG","6326"]],
>> PRIMEM["Greenwich",0],
>> UNIT["degree",0.0174532925199433],
>> AUTHORITY["EPSG","4326"]]
>> Origin = (-180.000000000000000,90.000000000000000)
>> Pixel Size = (0.360000000000000,-0.360000000000000)
>> Metadata:
>> TIFFTAG_DOCUMENTNAME=/tmp/world.tif
>> TIFFTAG_XRESOLUTION=72
>> TIFFTAG_YRESOLUTION=72
>> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
>> AREA_OR_POINT=Area
>> Image Structure Metadata:
>> INTERLEAVE=BAND
>> Corner Coordinates:
>> Upper Left (-180.0000000, 90.0000000) (180d 0'0.00"W, 90d 0'0.00"N)
>> Lower Left (-180.0000000, -90.0000000) (180d 0'0.00"W, 90d 0'0.00"S)
>> Upper Right ( 180.0000000, 90.0000000) (180d 0'0.00"E, 90d 0'0.00"N)
>> Lower Right ( 180.0000000, -90.0000000) (180d 0'0.00"E, 90d 0'0.00"S)
>> Center ( 0.0000000, 0.0000000) ( 0d 0'0.01"E, 0d 0'0.01"N)
>> Band 1 Block=1000x8 Type=Byte, ColorInterp=Gray
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110926/1a9dbe39/attachment.html
