[mapserver-users] Displaying repeated values in label
Toni Martínez
tmartinh at gmail.com
Mon Sep 26 12:02:45 EDT 2011
Thank you very much. You touched the right key.
Regards,
2011/9/26 thomas bonfort <thomas.bonfort at gmail.com>
> remove the MINDISTANCE keywords from your labels, they prevent
> duplicate labels from appearing closer than the specified distance
> (i.e. 600 in your case) which depending an your image size can mean
> that your 0.0 is only displayed once.
> thomas
> On Mon, Sep 26, 2011 at 17:52, Toni Martínez <tmartinh at gmail.com> wrote:
> > Hi all,
> > I am using MapServer version 5.6.1 reading data from Postgis.
> > One of the layers I am working with makes use of labels displaying data
> from
> > a Postgis column over a marker on the map. Everything seems to be working
> > fine but some data to be displayed on labels is 0.0 In such case,
> mapserver
> > only displays one marker with its label.
> > Because I need all markers and labels to be represented on that layer
> even
> > if values are the same, I have been trying some options that I read in
> > mapserver official docs like MINDISTANCE or FORCE or PROCESSING
> > "LABEL_NO_CLIP=ON" with no results.
> > Please take a look at my layer's code.
> > LAYER
> > NAME pern_lectura
> > GROUP overlays
> > TYPE POINT
> > STATUS OFF
> > PROCESSING "CLOSE_CONNECTION=DEFER"
> > CONNECTIONTYPE POSTGIS
> > CONNECTION 'user=postgres password=xxxxxx dbname=UAS host=xxxxxxx
> > port=5432'
> > DATA "the_geom from gis_schema.perno_estat_geom using SRID=23031
> using
> > unique id_perno"
> > FILTER "nombre_anillo='A903'"
> > OPACITY 100
> > CLASS
> > NAME 'Normalitat'
> > EXPRESSION ([estat] = 0)
> > STYLE
> > SYMBOL "quadrat"
> > SIZE 15
> > COLOR 45 181 45
> > OUTLINECOLOR 0 0 0
> > END
> > STYLE
> > SYMBOL "circle"
> > SIZE 11.25
> > COLOR 204 204 255
> > OUTLINECOLOR 0 0 0
> > END
> > STYLE
> > SYMBOL "creu"
> > SIZE 6
> > COLOR 0 0 0
> > END
> > LABEL
> > MINFEATURESIZE 80
> > TYPE TRUETYPE
> > FONT "arial"
> > SIZE 8
> > ANGLE FOLLOW
> > COLOR 25 25 175
> > OUTLINECOLOR 255 255 255
> > MINDISTANCE 600
> > PARTIALS FALSE
> > END
> > END
> > CLASS
> > NAME 'Notificació'
> > EXPRESSION ([estat] = 1)
> > STYLE
> > SYMBOL "quadrat"
> > SIZE 15
> > COLOR 226 226 0
> > OUTLINECOLOR 0 0 0
> > END
> > STYLE
> > SYMBOL "circle"
> > SIZE 11.25
> > COLOR 204 204 255
> > OUTLINECOLOR 0 0 0
> > END
> > STYLE
> > SYMBOL "creu"
> > SIZE 6
> > COLOR 0 0 0
> > END
> > LABEL
> > MINFEATURESIZE 80
> > TYPE TRUETYPE
> > FONT "arial"
> > SIZE 8
> > ANGLE FOLLOW
> > COLOR 25 25 175
> > MINDISTANCE 600
> > PARTIALS FALSE
> > END
> > END
> > CLASS
> > NAME 'Preavís'
> > EXPRESSION ([estat] = 2)
> > STYLE
> > SYMBOL "quadrat"
> > SIZE 15
> > COLOR 255 130 0
> > OUTLINECOLOR 0 0 0
> > END
> > STYLE
> > SYMBOL "circle"
> > SIZE 11.25
> > COLOR 204 204 255
> > OUTLINECOLOR 0 0 0
> > END
> > STYLE
> > SYMBOL "creu"
> > SIZE 6
> > COLOR 0 0 0
> > END
> > LABEL
> > MINFEATURESIZE 80
> > TYPE TRUETYPE
> > FONT "arial"
> > SIZE 8
> > ANGLE FOLLOW
> > COLOR 25 25 175
> > MINDISTANCE 600
> > PARTIALS FALSE
> > END
> > END
> > CLASS
> > NAME 'Atenció'
> > EXPRESSION ([estat] = 3)
> > STYLE
> > SYMBOL "quadrat"
> > SIZE 15
> > COLOR 212 0 0
> > OUTLINECOLOR 0 0 0
> > END
> > STYLE
> > SYMBOL "circle"
> > SIZE 11.25
> > COLOR 204 204 255
> > OUTLINECOLOR 0 0 0
> > END
> > STYLE
> > SYMBOL "creu"
> > SIZE 6
> > COLOR 0 0 0
> > END
> > LABEL
> > MINFEATURESIZE 80
> > TYPE TRUETYPE
> > FONT "arial"
> > SIZE 8
> > ANGLE FOLLOW
> > COLOR 25 25 175
> > MINDISTANCE 600
> > PARTIALS FALSE
> > END
> > END
> > PROJECTION
> > "init=epsg:23031"
> > END
> > METADATA
> > "wms_srs" "EPSG:23031"
> > "wms_title" "Perns lectura"
> > "wms_include_items" "id"
> > END
> > TEMPLATE "templates/template.php"
> > TOLERANCE 1
> > PROCESSING "LABEL_NO_CLIP=ON"
> > TYPE ANNOTATION
> > LABELITEM lectura_dif
> > CLASS
> > LABEL
> > COLOR 0 0 0
> > TYPE TRUETYPE
> > FONT arial
> > SIZE 10
> > ANTIALIAS TRUE
> > POSITION AUTO
> > FORCE TRUE
> > PARTIALS FALSE
> > MINDISTANCE 3000
> > BUFFER 4
> > PARTIALS FALSE
> > END
> > END
> > END
> > Any help will be greatly appreciated.
> > Regards,
> > Toni M.
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110926/6c5e5f9a/attachment.html
