[mapserver-users] passing cgi query params to wms layers
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Sep 27 12:29:38 EDT 2011
On 9/27/2011 9:27 AM, Puneet Kishor wrote:
> On Sep 26, 2011, at 11:22 PM, Mr. Puneet Kishor wrote:
>> On Sep 26, 2011, at 11:04 PM, Stephen Woodbridge wrote:
>>> On 9/26/2011 10:29 PM, Puneet Kishor wrote:
>>>> I am using OpenLayers as the front-end, requesting a WMS layer from MapServer that is getting data from Pg. My DATA statement is like so
>>>> DATA "the_geom FROM (SELECT gid, pc, the_geom FROM table) t USING UNIQUE gid USING srid=4326"
>>>> FILTER "pc = 'na'"
>>>> The above works fine. However, I would like to send the value of "pc" from OpenLayers (that is another problem that I am experiencing; I have asked on OL list on how to send query params to WMS layers, but if any of you know the solution, I would welcome that). In any case, I thought (naively), that I could change my FILTER statement like so
>>>> FILTER "pc = '[pc]'"
>>>> I tried sending a WMS query directly to test the above like so [http://server/cgi-bin/app?.. blah ..&pc=na] but no joy. Forcing a query error showed me that MapServer was executing the following
>>>> select .. from (..) t where the_geom&& GeomFromText(..) and (pc = '[pc]')
>>>> How can I dynamically supply MapServer a filter value?
>>> Does this doc answer your question?
>>> http://mapserver.org/cgi/runsub.html
>> Yes it does. I had not seen that doc (hence, I was naively trying [var] kinda sub)
> So, it seems I can't use Perl compatible regexps inside the map file for runtime substitution. For example, the following fails
> 'pc_validation_pattern' '^\w\w$'
> with "msValidateParameter(): Regular expression error. Parameter pattern validation failed." But the following works
> 'pc_validation_pattern' '^[a-zA-Z][a-zA-Z]$'
> Is there a compile time switch to make MapServer Perl-savvy?
No, that would be a nice option. I'm not sure if there is a ticket or
not for adding pcre support. If not you might want to add one. I find
Perl expressions much easier to work with.
-Steve W
