[mapserver-users] Rendering weather data
Brent Fraser
bfraser at geoanalytic.com
Tue Sep 27 15:57:21 EDT 2011
Norman,
Many thanks for the link; it's good to see how others have approached
the problem. The font referenced is an ESRI font so I don't think I can
use it due to copyright, but perhaps I could construct my own using the
same glyph indexes for compatibility.
Best Regards,
Brent Fraser
On 9/27/2011 12:09 PM, Norman Vine wrote:
> On Sep 27, 2011, at 2:03 PM, Paul Ramsey wrote:
>> Once you have vectors, the classic trick I've seen for doing the barbs
>> is to do math to map the windspeed into an appropriate char() value
>> and store the barbs as TTF font entries. So you only end up with one
>> class, and the barb is an appropriately rotated label.
> This might help
> http://carocoops.org/bb/viewtopic.php?t=169
>> P.
>> On Tue, Sep 27, 2011 at 10:31 AM, Brent Fraser
>> <bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>> wrote:
>>> At FOSS4G I was struck by the number of presentations involving
>>> weather
>>> data and time series display. Maybe I noticed because I have a need to
>>> render wind velocity in KML, and while I haven't settled on
>>> mapserver to do
>>> the rendering I've been wondering how to render wind barb symbols (see
>>> attached graphics) efficiently.
>>> One problem is the source data: the magnitude is in one raster file
>>> (GRIB
>>> format, float64) and the direction in another. GDAL's OGR library will
>>> read the GRIB files, but I don't know of any way to use two rasters to
>>> define a vector layer. I think there is some work going on with
>>> respect to
>>> displaying vector field data in mapserver, so maybe this will be
>>> solved by
>>> that work. Otherwise pre-processing the two rasters into a point
>>> datasource
>>> containing lon,lat,speed,direction attributes may be the way to go.
>>> The other issue of wind barb symbol rendering may have to be solved
>>> by hand
>>> constructing a barb for 0 knots, 5 knots, etc (50-ish symbols?) ,
>>> and having
>>> 50-ish corresponding classes (this could be a performance problem for
>>> mapserver). But I'm open to better ideas... SLD? HTTP/CGI request?,
>>> something like one class of:
>>> CLASS
>>> STYLE
>>> GEOMTRANSFORM "start"
>>> COLOR 0 255 0
>>> SIZE 15.0
>>> SYMBOL "http://localhost/symbolgen?[speed]"
>>> ANGLE [direction]
>>> END
>>> END
>>> but likely the cost of getting the symbol would be greater that
>>> creating 50
>>> separate class objects.
>>> And for those interested in mapping and graphing weather data, have
>>> a look
>>> at http://www.ncl.ucar.edu/Applications/
>>> especially http://www.ncl.ucar.edu/Applications/barb.shtml
>>> Best Regards,
>>> Brent Fraser
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110927/42a62715/attachment.html
