[mapserver-users] TILEINDEX layer problem mapserver 6.0.1
Simon Mercier
mercier.simon at gmail.com
Wed Sep 28 01:48:59 EDT 2011
Hi list, I try to migrate a map service to Mapserver 6.0.1 that work
perfectly with a Mapserver 5.0.3 and I have a strange behavior with a
TILEINDEX layer. If you look the picture(in yellow you have the raster
coverage)(http://mapcoop.org/www-demo/bugorthos.JPG), you see that my image
coverage is not the same scale? The raster coverage fit exactly with the
WMS_EXTENT tag of my TILEINDEX layer. Moreover, if I comment the WMS_EXTENT
tag no raster appears in my map. Images are ECW files and projection is
EPSG:32187. The GETMAP is EPSG:32198. I had to compile GDAL 1.8.0 to use
ECW driver. Did I miss something? Where should I look?
/cgi-bin/orthos_sim?REQUEST=
GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=T_AN2000_MTM7&STYLES=&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SRS=EPSG:32198&BBOX=-452656.626506024,-11030.1204819277,279310.277253593,647379.518072289&WIDTH=1015&HEIGHT=913
MAP
NAME "orthos_sim"
EXTENT -1100000 -23500 1100000 2253500
CONFIG MS_ERRORFILE "/var/services/mapserv/logs/mapserv-sim.log"
WEB
QUERYFORMAT "text/xml"
BROWSEFORMAT "text/xml"
IMAGEPATH "/tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"wms_title" "orthos"
"wms_abstract" "Service web d'imagerie
Orthosphoto"
"wms_description" "Ce service "
"wms_keywordlist" "orthophotographie"
"wms_onlineresource" "http://sigdev/cgi-bin/orthos_sim?"
"wms_server_version" "1.1.1"
"wms_format" "image/png"
"wms_getcontext_enabled" "1"
"ows_enable_request" "*"
END
END
PROJECTION
"init=epsg:32198"
END
LAYER
NAME "T_AN2000_MTM7"
TYPE RASTER
debug 5
EXTENT 160000 4960000 450000 5450000
TILEINDEX "/var/www/wms/tmp/AN2000_MTM07.shp"
TILEITEM "location"
METADATA
"wms_title" "T_AN2000_MTM7"
"wms_name" "an 2000 mtm 07"
"wms_kaywordlist" "orthos"
"wms_abstract" "Couche d'orthos"
"wms_srs" "EPSG:32198 EPSG:900913 EPSG:32184
EPSG:32186 EPSG:32187 EPSG:32188 EPSG:32189 EPSG:32190"
"wms_extent" "160000 4960000 450000 5450000"
END
PROJECTION
"init=epsg:32187"
END
END
END
Simon Mercier
Saint-Nicolas, QC
Canada G7A 4Y2
www.mgeospatial.com
linkedIn : http://ca.linkedin.com/in/simonmercier
twitter : http://twitter.com/simonmercier
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110928/79ce5c1c/attachment.html
