[mapserver-users] Using a Symbol instead of text for a label
Matt McClelland
matt at wildwalks.com
Wed Sep 28 17:31:31 EDT 2011
Thanks David
That Cluster function is very impressive (as is Mapserver).
Using expressions to find common cluster problems I can fairly easily
resolve about 90% of my issues, a good solution.
Thanks
Matt :)
On Wed, Sep 28, 2011 at 11:47 PM, Fawcett, David (MPCA) <
david.fawcett at state.mn.us> wrote:
> Matt, ****
> I haven’t fully thought it through, but maybe the new Cluster functionality
> might work for this. You could have a generic park symbol for the cluster
> symbol.****
> http://mapserver.org/mapfile/cluster.html****
> David.****
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Matt McClelland
> *Sent:* Tuesday, September 27, 2011 6:15 PM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] Using a Symbol instead of text for a label***
> Hi
> I have a bunch of symbols that overlap on a map. EG at a park where I want
> to show an symbol for playground, toilet and picnic tables. The data for
> each of these items are individual point data items.
> I would like to ask mapserver, very kindly, to 'tile' nearby symbols into a
> group
> OR
> Use the main symbol like a label. So that I could have a dot where the
> play equipment is, then nearby have the symbol for the play equipment. This
> is obviously very easy to do with text, but is it possible with a symbol??
> I have tried this
> CLASS
> EXPRESSION /play|playground/
> NAME "Children's Playground"
> STYLE
> SYMBOL 'waypoint'
> color 255 0 0
> SIZE 5
> END
> LABEL
> STYLE
> SYMBOL '/var/www/osm/kml/icons/play.png'
> Size 10
> END
> ...text styleing info....
> END
> END
> I get my 'waypoint' dot and the play.png in the same location. I would
> like the play.png to be positioned AUTO like I can with text.
> Any ideas??
> Thanks
> Matt :)****
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110929/b32cbf17/attachment.html
