[mapserver-users] Parameter substitution problem
Asad Ullah
Asad.Ullah at sigmaspace.com
Thu Sep 29 09:53:06 EDT 2011
I don't think (-) is a problem because I have tried changing (-) with (_) in the file name without success.
-----Original Message-----
From: Mr. Puneet Kishor [mailto:punk.kish at gmail.com]
Sent: Thursday, September 29, 2011 9:47 AM
To: Asad Ullah
Cc: Steve Lime; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Parameter substitution problem
On Sep 29, 2011, at 8:22 AM, Asad Ullah wrote:
> Steve,
> Thanks very much for your help. Adding quote did not change anything. However, if I change file name from, for example, "OMI-Aura_L3-OMCLDRRclpWMSNRT_20110922.png" to " OMI_OMCLDRRclpWMSNRT_20110922.png" and do the substitution as:
> "/cgi-bin/mapserv.cgi?map_layer[OMI_CP]=DATA+OMI_OMCLDRRclpWMSNRT_"+ amsreDate + ".png"
> It would work. Where the validation block is same as:
> VALIDATION
> 'DATA' '^OMI_.*\.png$'
> END
> So, do you think the problem is with validation definition?
Could it be the dashes (-) in the problematic file name?
> Thanks,
> Asad
> From: Steve Lime [mailto:sdlime at gmail.com]
> Sent: Wednesday, September 28, 2011 11:27 PM
> To: Asad Ullah; mapserver-users at lists.osgeo.org
> What happens if you quote the variable in the CGI call, that is:
> "/cgi-bin/mapserv.cgi?map_layer[OMI_CP]=DATA+'OMI-Aura_L3-OMCLDRRclpWMSNRT_"+
> amsreDate + ".png'"
> Note the single quotes in the DATA value... I'll try to whip up local test case.
> Steve
> On Tue, Sep 27, 2011 at 4:28 PM, Asad Ullah <Asad.Ullah at sigmaspace.com> wrote:
>> Steve,
>> DATA in the URL has quotes as:
>> "/cgi-bin/mapserv.cgi?map_layer[OMI_CP]=DATA+OMI-Aura_L3-OMCLDRRclpWMSNRT_"+
>> amsreDate + ".png"
>> I unquoted the value in mapfile but there was no error. Any more suggestion?
>> Thanks,
>> Asad
>> Sent: Friday, September 23, 2011 4:55 AM
>> To: Asad Ullah
>> Cc: mapserver-users at lists.osgeo.org
>> My guess is the validation is correct but the syntax of the URL parameter is
>> is wrong in that the value passed for DATA is not quoted. If you unquote the
>> default value in your mapfile does that result in a error? That would be an
>> easy way to test the need for quotes.
>> One last idea, while map_layer... should work, try map.layer... instead as
>> you variable name.
>> If you're really are just replacing the date part you could do that by doing
>> a runtime sub...
>> DATA "OMI-Aura_L3-OMCLDRRclpWMSNRT_%date%.png"
>> VALIDATION
>> date 'regex'
>> END
>> And then you pass date as a CGI variable.
>> Steve
>> On Thursday, September 22, 2011, Asad Ullah <Asad.Ullah at sigmaspace.com>
>> wrote:
>>> List,
>>> I am trying to substitute DATA parameter in my mapfile with a call from
>>> Openlayers as follow:
>>> map_layer[OMI_CP]=DATA+OMI-Aura_L3-OMCLDRRclpWMSNRT_"+ amsreDate + ".png"
>>> The mapfile is:
>>> LAYER
>>> NAME "OMI_CP"
>>> TYPE RASTER
>>> STATUS DEFAULT
>>> OFFSITE 0 0 0
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> DATA "OMI-Aura_L3-OMCLDRRclpWMSNRT_20110922.png"
>>> VALIDATION
>>> END
>>> The call should change the date part (20110922) of the png filename but it
>>> is not doing it. Can anyone point to what I am doing wrong here?
>>> Thanks,
>>> Asad
