[mapserver-users] Basic Templating
Sowmya Tiramdasu
stiramdasu at qcoherent.com
Thu Aug 2 14:04:03 PDT 2012
Hi ,
I am trying to implement templating taking the help of the mapserver
tutorial. I created my own map file, which works fine. I get the output as
desired when I use mode=map. Now I am trying to include a template for my
example. I created a new template file 'gmapNew.html' . I added the
reference to this template file in my map file. Yet When I am submitting a
query, the template values are not being substituted correctly and so not
getting my required result.
The snippet of my map file where I am referencing my template file.
MAP
IMAGETYPE PNG
EXTENT -9423052.40 4582638.15 -9414491.41
4589289.39 # extents of las file for 3875 using cs2cs
#EXTENT 1525556.83 190608.70 1547770.63 207656.82
#las files
#EXTENT -9435462.86 4562596.42 -9387971.96
4608897.38 # sbet lat lon to extent using cs2cs
SIZE 1020 980
SHAPEPATH "../data"
SYMBOLSET "../symbols/symbols35.sym"
#TRANSPARENT ON
IMAGECOLOR 0 0 0
FONTSET "../fonts/fonts.list"
PROJECTION
#"init=epsg:2246"
"init=epsg:3857"
END
WEB
TEMPLATE "gmapNew.html"
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"wms_enable_request" "*"
"wms_title" "WMS Lidar
Server"
"wms_onlineresource"
"http://localhost:8080/keenland?"
"wms_srs" "espg:32617"
END
END
END
My template file.
<!-- MapServer Template -->
<!DOCTYPE html
PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="content-type" content="text/html; charset=utf-8"/>
<title>Google/MapServer Tile Example</title>
<link type="text/css" rel="stylesheet" href="[root]/ms35.css" />
</head>
<body >
<!-- The central form the application is based on. -->
<form name="mapserv" method="GET" action="[program]">
<input type="hidden" name="root" value="[root]" />
<input type="hidden" name="program"
value="[program]" />
<input type="hidden" name="map_web"
value="[map_web]" />
<input type="hidden" name="map"
value="[map]" />
<input type="hidden" name="imgext"
value="[mapext]" />
<input type="hidden" name="imgxy"
value="[center]" />
<input type="hidden" name="layers"
value="[layers]" />
<input type="hidden" name="zoom"
value="[zoom]" />
<table border=0 cellpadding=5>
<tr>
<!-- First
column: Map and scale bar -->
<td
align=center>
<!-- The map -->
<input type="image" name="img" src="[img]"
style="border:0;width:300;height:400">
<br>
</td>
<td>
<div align="center">
<input type="submit" name="submit" value="Refresh">
</div>
</td>
<!-- Second
column: Zoom direction, Legend and Reference -->
<td
valign=top>
<!-- Zoom direction -->
<b>Map Controls</b><br> Set your zoom option:<br>
<select name="zoom" size="1">
<option value="2" [ z o o m _ 2 _ s e l e c t ] > Zoom in 2 times
<option value="1" [ z o o m _ 1 _ s e l e c t ] > Recenter Map
<option value="-2" [ z o o m _ - 2 _ s e l e c t ] > Zoom out 2 times
</select>
<br>
</td>
</tr>
</table>
</form>
</body>
</html>
Can anyone please help me . Any help is greatly appreciated. Thanks in
advance!
-Sowmya.
_______________________________
Sowmya Tiramdasu
QCoherent Software
9668 Madison Blvd., Suite 202
Madison, AL 35758
(256) 461-8289 Telephone
(256) 461-8249 Fax
<http://www.geocue.com/> www.geocue.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120802/479934bb/attachment-0001.html>
