[mapserver-users] changing opacity of a layer for a single client using map server
Sowmya Tiramdasu
stiramdasu at qcoherent.com
Thu Aug 2 14:09:54 PDT 2012
Hi All,
I have a question relating to opacity of a layer. My requirement is to
change the opacity of a layer for a particular client. I thought, I can
achieve this using map script. But, one thing which is not clear to me is :
If I change the opacity of a layer through the map script , will the changes
get reflected back in to the map file and then to any other clients
accessing that map file?
If I make changes to the existing map object using mapscript , will those
changes be reflected back on to the map file? Please someone clarify me this
point.
Thanks in advance!
-Sowmya.
_______________________________
Sowmya Tiramdasu
QCoherent Software
9668 Madison Blvd., Suite 202
Madison, AL 35758
(256) 461-8289 Telephone
(256) 461-8249 Fax
<http://www.geocue.com/> www.geocue.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120802/43b725a8/attachment.html>
