[mapserver-users] Using spatialite with mapserver
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Aug 2 14:27:23 PDT 2012
The SELECT alternative works fine for me but I do not have multiple geometries. I made a very fast test on Spatialite side and it seems to be possible to run "Recover geometry column" and "Create spatial index" for multiple geometries but I did not test the result with Mapserver.
I would recommend you to check first your geometry_columns table and see it there is a line for the geometry you want to use and if spatial index is OK. If they are OK make a simplified test. Create a single geometry table as
CREATE table test as
SELECT geom1, attr1... FROM...
Do "Recover geometry column" and "Create spatial index" things for the new table and have a try with Mapserver.
GDAL version must be 1.9 or higher or things will be far too slow.
This document may also be useful for you
http://latuviitta.org/documents/Super_easy_WMS_server.pdf
-Jukka Rahkonen-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] käyttäjän Andrea Peri [aperi2007 at gmail.com] puolesta
Lähetetty: 2. elokuuta 2012 23:03
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] Using spatialite with mapserver
I'm try-ing to use spatialite with mapserver.
is this mapfile configuration ok for spatialite ?
CONNECTIONTYPE OGR
CONNECTION '/..path-to../spatialite_file.sqlite'
DATA 'SELECT field1, field2, field3, geometry from table'
It seem don't work.
Instead work perfectly this other configuration:
CONNECTIONTYPE OGR
CONNECTION '/home/vector/vettoriali/db_catasto/regione_toscana/adt_toscana.sqlite'
DATA 'table'
Unfortunately this second configuration don't allow to choose the geometry field , necessary when spatialite table as two or more geometry field.
Thx,
Andrea Peri
qwerty àèìòù
