[mapserver-users] changing opacity of a layer for a single client using map server
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Thu Aug 2 14:45:27 PDT 2012
The mapfile is loaded into memory and then MapScript acts upon those structures. The original is unchanged.
Steve
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Sowmya Tiramdasu
Sent: Thursday, August 02, 2012 4:10 PM
To: 'Mapserver-users'
Subject: [mapserver-users] changing opacity of a layer for a single client using map server
Hi All,
I have a question relating to opacity of a layer. My requirement is to change the opacity of a layer for a particular client. I thought, I can achieve this using map script. But, one thing which is not clear to me is : If I change the opacity of a layer through the map script , will the changes get reflected back in to the map file and then to any other clients accessing that map file?
If I make changes to the existing map object using mapscript , will those changes be reflected back on to the map file? Please someone clarify me this point.
Thanks in advance!
-Sowmya.
_______________________________
Sowmya Tiramdasu
QCoherent Software
9668 Madison Blvd., Suite 202
Madison, AL 35758
(256) 461-8289 Telephone
(256) 461-8249 Fax
www.geocue.com<http://www.geocue.com/>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120802/dc5feb1b/attachment.html>
